Home » Eclipse Projects » Eclipse Platform » 2024-06 required Java Version: Wiki vs. eclipse.ini(Required Java Version for 2024-06: discrepancy between wiki and eclipse.ini)
2024-06 required Java Version: Wiki vs. eclipse.ini [message #1867281] Thu, 20 June 2024 10:18 Go to next message
we just wanted to jump on the new IDE 2024-06.
Eclipse Wiki says that minimum Java version requirement for 2024-06 is 17:
https://wiki.eclipse.org/Eclipse/Installation#Eclipse_4.28_.282023-06.29
But on downloading and running the IDE we identified the entry
-Dosgi.requiredJavaVersion=21
Furthermore, the Info shell of the IDE does not work correctly, when launching with Java 17, runs correct when running Java 21.
So, I would like to ask if the entry in the Wiki is wrong or there is a different reason.
Re: 2024-06 required Java Version: Wiki vs. eclipse.ini [message #1867284 is a reply to message #1867281] Thu, 20 June 2024 11:21 Go to previous messageGo to next message
That's a really old entry and there is no entry for 4.32/2024-06. No one is maintaining that wiki and it can't be maintained anymore because it's read only. Maybe this page has not popped up for you yet?
https://www.eclipse.org/setups/sponsor/
Re: 2024-06 required Java Version: Wiki vs. eclipse.ini [message #1867296 is a reply to message #1867281] Fri, 21 June 2024 00:32 Go to previous message
Thx for the hint.
I didn't realize that the wiki is outdated, 4 eyes are better than 2. Then, i's clearly defined.
Previous Topic:How to remove ANT Configurations?
Next Topic:Running Multiple Eclipse Versions
Current Time: Sat Jun 07 14:35:40 EDT 2025
Powered by FUDForum. Page generated in 0.03638 seconds
