Home » Modeling » TMF (Xtext) » XMI to Xtext DSL
XMI to Xtext DSL [message #1807846] Tue, 11 June 2019 00:01 Go to next message
I have an XMI file derived from a DSL metamodel.
I would like to convert it back to the DSL, i.e myfile.mydsl.
Is this possible using Eclipse, without doing this programmatically ?
[Updated on: Tue, 11 June 2019 00:03] by Moderator
Re: XMI to Xtext DSL [message #1807850 is a reply to message #1807846] Tue, 11 June 2019 02:06 Go to previous messageGo to next message
hi, i am not aware of any non programmatic option for this
Re: XMI to Xtext DSL [message #1807851 is a reply to message #1807850] Tue, 11 June 2019 02:10 Go to previous messageGo to next message
I mean how can I transform a myfile.xmi to myfile.mydsl in Eclipse ?
Re: XMI to Xtext DSL [message #1807852 is a reply to message #1807851] Tue, 11 June 2019 02:20 Go to previous messageGo to next message
do it programmatically. or dont create an xmi in the first place
Re: XMI to Xtext DSL [message #1807857 is a reply to message #1807852] Tue, 11 June 2019 03:41 Go to previous messageGo to next message
You haven't told us what the relationship is between the DSL and the XMI.
If you have the 'trivial' relationship whereby Xtext treats the DSL source text and its underlying parsed EMF model as equivalent, then you should be able to open the XMI with your DSL editor see the serialized text and copy/save it as text.
If you have a non-trivial relationship, then the programmer of your forward conversion from DSL to XMI may also program the reverse conversion from XMI to DSL so that you can open in your DSL editor as above. (This works for the OCL, QVTc, QVTi, QVTr editors.)
Ed Willink
Re: XMI to Xtext DSL [message #1807868 is a reply to message #1807857] Tue, 11 June 2019 04:10 Go to previous messageGo to next message
You may get some inspiration from the following blog post: https://blogs.itemis.com/en/combining-emf-models-with-xtext-dsls
It contains (among others) an example implementation for:
An additional feature could be to add Xtext serialization support to EMF models; when the user edits an EMF element and saves the *.emfstatemachine file, we want that the corresponding *.statemachine Xtext DSL file is automatically generated.
Re: XMI to Xtext DSL [message #1866798 is a reply to message #1807868] Thu, 06 June 2024 16:47 Go to previous message
I ended up implementing programmatically in my plugin.
Thank you all for your time
Previous Topic:Embedding Comments in Custom DSL Files
Next Topic:Embedding Comments in Custom DSL Files
Current Time: Mon Jul 21 01:43:55 EDT 2025
Powered by FUDForum. Page generated in 0.06901 seconds
