Home » Archived » BIRT » German umlaute in XML data source do not work
German umlaute in XML data source do not work [message #177606] Fri, 14 July 2006 04:05 Go to next message
Originally posted by: abushnaq.ricoh-europe.com
I noticed that german umlaute e.g. ä(ae ) do not correctly display in BIRT
if they are read from a XML data source although I use UTF8 encoding which
should even allow languages such as arabic.
I use BIRT 2.1 release.
Does anybody know if this is a bug or if there is something I can do?
Re: German umlaute in XML data source do not work [message #186659 is a reply to message #177606] Wed, 23 August 2006 06:40 Go to previous messageGo to next message
Originally posted by: Norbert.Mallien.AOL.com
Hello Abdalla,
I made the same experience. Did you find any solution for this?
Within the Eclipse Report Designer the report runs without any problems, but
an external WebApp fails.
Norbert
"Abdalla Bushnaq" <abushnaq@ricoh-europe.com> schrieb im Newsbeitrag
news:a9646d16c60785ebb589151cedd37450$1@www.eclipse.org...
Re: German umlaute in XML data source do not work [message #189360 is a reply to message #177606] Thu, 07 September 2006 07:43 Go to previous message
Originally posted by: calmacroi.myrddin.ch
hi
i had the same problem, after birt report desinger opened the .rptdesign
-file the encoding was always reset to UTF-8. German umlaute worked in
my case by changing encoding-schema always to ISO8859-1..
greets
patrick
> BIRT if they are read from a XML data source although I use UTF8
> encoding which should even allow languages such as arabic.
Previous Topic:How to access Reports default and User properties in Dynamic Text -item ?
Next Topic:Notice: a possible mistake in BIRT website.
Current Time: Mon Nov 10 00:15:00 EST 2025
Powered by FUDForum. Page generated in 0.06491 seconds
