Home » Eclipse Projects » e(fx)clipse » Unable to create New FXML Document and error build.fxbuild(Unable to create New FXML Document and error build.fxbuild and java.lang.NoClassDefFoundError: org/eclipse/jface/databinding/swt/WidgetProperties)
Unable to create New FXML Document and error build.fxbuild [message #1859486] Sat, 10 June 2023 03:57 Go to next message
Basically, I cover the JavaFX learning process with youtube tutorials. I'm having issues when it gets to this stage:
After right-clicking on "Package name in any name" > New > Other > JavaFX folder > New FXML Document it doesn't generate anything. There is no error in the "Problem" field, which is the bottom tab. So after a long time I clicked on the build.fxbuild file in the left workspace out of pure curiosity. I saw many mistakes written in front of me. I wonder if this error and the reason why it doesn't interact when I click "New FXML Documents" might be related to this error? How can I solve this problem? Please can you help me? I would like to thank your teams who are already working and working and all users who are helpful or not.
at org.eclipse.fx.ide.jdt.ui.internal.editors.JFXBuildConfigurationEditor.createPageOverview(JFXBuildConfigurationEditor.java:803)
at org.eclipse.fx.ide.jdt.ui.internal.editors.JFXBuildConfigurationEditor.createPages(JFXBuildConfigurationEditor.java:658)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:333)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:158)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:365)
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:104)
at java.base/java.lang.reflect.Method.invoke(Method.java:578)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:987)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:952)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:141)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:395)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:322)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:202)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:995)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:763)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:728)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:712)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.lambda$0(PartServiceImpl.java:105)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:183)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4803)
at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:660)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:624)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:790)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1264)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3233)
at org.eclipse.ui.internal.WorkbenchPage.lambda$11(WorkbenchPage.java:3123)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3121)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3091)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3082)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:548)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:508)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:367)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:172)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:288)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:254)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:274)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:252)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:366)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$3.open(PackageExplorerPart.java:545)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:800)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:174)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:797)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1116)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:296)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:331)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4274)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4072)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:643)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:550)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:171)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
Caused by: java.lang.ClassNotFoundException: org.eclipse.jface.databinding.swt.WidgetProperties cannot be found by org.eclipse.fx.ide.jdt.ui_3.8.0.202204150904
at org.eclipse.osgi.internal.loader.BundleLoader.generateException(BundleLoader.java:541)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:536)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:416)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:168)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
... 98 more
  • Attachment: error.png
    (Size: 114.70KB, Downloaded 214 times)
Re: Unable to create New FXML Document and error build.fxbuild [message #1859770 is a reply to message #1859486] Mon, 26 June 2023 09:47 Go to previous messageGo to next message
I have the same problem, any solution?
Re: Unable to create New FXML Document and error build.fxbuild [message #1860905 is a reply to message #1859770] Thu, 07 September 2023 18:45 Go to previous messageGo to next message
a solution is given in Stackoverflow subject 74758570
(can't include links)
Re: Unable to create New FXML Document and error build.fxbuild [message #1865469 is a reply to message #1860905] Sat, 04 May 2024 00:45 Go to previous message
Laurent Buisson wrote on Thu, 07 September 2023 22:45
Thanks! :) That worked for me. I just installed Eclipse 2024-03, then installed e(fx)clipse from the standard site, but then ran into the same problem as the OP. So I upgraded e(fx)clipse from 3.9.0 to 3.10.0 using the nightly build site, as mentioned in StackOverflow.
Previous Topic:Missing OSGi-Bundle Dependencies
Next Topic:efxclipse 3.x and the path to 4.0
Current Time: Tue Nov 04 20:44:14 EST 2025
Powered by FUDForum. Page generated in 0.38165 seconds
