| Loading Excel file in Ant [message #1865274] |
Mon, 29 April 2024 15:16  |
I am trying to load an Excel file to pass to an EOL file in my Ant workflow. I am trying to load it using the code below based on the example in [1].
<epsilon.loadModel name="E" impl = 'org.eclipse.epsilon.emc.spreadsheets.excel.ExcelModel'>
<parameter name ="SPREADSHEET_FILE" file = "excel.xlsx"/>
<parameter name ="CONFIGURATION_FILE" file = "mapping.xml"/>
</epsilon.loadModel>
But the code throws this error: java.lang.NullPointerException: Cannot invoke "org.eclipse.epsilon.common.dt.launching.extensions.ModelTypeExtension.createModel()" because the return value of "org.eclipse.epsilon.common.dt.launching.extensions.ModelTypeExtension.forType(String)" is null
Thanks for your help
[1] https://eclipse.dev/epsilon/doc/articles/running-epsilon-ant-tasks-from-command-line/
FUDForum. Page generated in 0.06095 seconds
