Home » Language IDEs » Eclipse Web Tools Platform Project (WTP) » Javascript syntax coloring(Invisible brackets, braces, parentheses)
Javascript syntax coloring [message #1864793] Tue, 09 April 2024 16:02 Go to next message
I have the latest Wild Web installed on 2024-03. With the web perspective selected my Javascript code on the generric text editor is not displaying brackets, braces, and parentheses. I am using the Light theme and haven't been able to affect a change. Any thoughts?
Re: Javascript syntax coloring [message #1864794 is a reply to message #1864793] Tue, 09 April 2024 18:33 Go to previous messageGo to next message
Technically that should go through https://github.com/eclipse-wildwebdeveloper/wildwebdeveloper/discussions , but how was it installed? Do you have a recent stable node.js version installed, or are you using the node runtime feature they provide?
Re: Javascript syntax coloring [message #1864813 is a reply to message #1864794] Wed, 10 April 2024 13:24 Go to previous messageGo to next message
Sorry, I'm still finding my way around. All installations are latest, node.js 20.11.1.
Re: Javascript syntax coloring [message #1865937 is a reply to message #1864813] Wed, 15 May 2024 10:44 Go to previous message
That's roughly the same version that they would have offered. I can only suggest opening an Issue or discussion there as the next step.
Previous Topic:XSL XML transformation not working and item not appearing for selection for HTTP server
Next Topic:Malformed URL on servlet publish with Apache tomcat
Current Time: Thu Sep 25 16:46:34 EDT 2025
Powered by FUDForum. Page generated in 0.03362 seconds
