Re: The operation cannot be completed. See the details [message #1864608 is a reply to message #1864583] |
Thu, 28 March 2024 02:33  |
Nguyen Ngoc Hieu wrote on Wed, 27 March 2024 02:49I am getting the error below when installing j2me plugins for Eclipse I don't know how to fix it, can someone help me?
Plugins: oracle-jmesdk-8-3-rr-eclipse-plugins.zip
The operation cannot be completed. See the details.Cannot complete the installation because one or more required items could not be found.
Software being installed: Java ME SDK Tools 8.3.0.201604172311 (com.oracle.jme.toolkit.feature.group 8.3.0.201604172311) Official Site
Missing requirement: Java ME SDK Tools 8.3.0.201604172311 (com.oracle.jme.toolkit.feature.group 8.3.0.201604172311) requires 'org.eclipse.equinox.p2.iu; org.eclipse.mtj.feature.group 0.0.0' but it could not be found
As per your post I give you my best please see blow info and follow step by step.
The error you're encountering indicates that the Java ME SDK Tools plugin requires another plugin called org.eclipse.mtj.feature.group, which is not found. This is likely the Mobile Tools for Java (MTJ) plugin, which needs to be installed before you can install the Java ME SDK Tools.
See below how to resolve this issue:
* Install the MTJ Plugin: Go to Eclipse > Help > Install New Software.
* In the Work with field, enter the update site URL for the MTJ plugin. If you're unsure of the URL, you can search for the "Eclipse MTJ plugin update site" or check the Eclipse Marketplace for the correct URL.
* Select the Mobile Tools for Java feature and proceed with the installation.
* After installing MTJ, restart Eclipse.
* Now, try installing the Java ME SDK Tools again using the same method.
If you still face issues, ensure that you're using a compatible version of Eclipse with the plugins you're trying to install. Sometimes, newer or older versions of Eclipse may not be compatible with certain plugins. Checking the compatibility on the official documentation or forums can provide guidance on the correct versions to use.
I hope my answer is helpful for you. If you want more details tell me.
Best Regard,
ryan1969
[Updated on: Fri, 29 March 2024 00:03] by Moderator
FUDForum. Page generated in 0.08570 seconds
