Home » Modeling » TMF (Xtext) » Context-specific scopeFor method dispatched without entering IScopeProvider.getScope
Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1863849] Fri, 01 March 2024 05:19 Go to next message
I have implemented a custom scope provider for my DSL.
In a nutshell:
@InjectLogger
Logger logger;
IScope getScope(EObject context, EReference ref) {
       logger.info("Providing scope for " + context);
       if (context instanceof SpecificObject1) {
          // Dispatch type-specific scopeFor
          logger.info("Dispatching scoper for SpecificObject1");
          scopeFor(context, ref);
       if (context instanceof SpecificObject2) {
       // If none of the if blocks match, use the default scope provider
       super.getScope(context, ref);
dispatch IScope scopeFor(SpecificObject1 context, EReference ref) {
       // Provide special scope for specific object
       // val scope = ...
       logger.info("Returning custom scope for SpecificObject1 instance");
       return scope;
Now, I have a situation where the scopeFor method for SpecificObject1 is dispatched without ever entering the getScope method defined by the IScopeProvider interface. This has become evident to me due to the missing log message, to be more specific, there is a case where "Returning custom scope for SpecificObject1 instance" is printed, but "Dispatching scoper for SpecificObject1" doesn't show up at all.
How is this possible? I have thought of the getScope method of the IScopeProvider interface as the "entry point" for all scoping.
Thanks in advance and regards
K.
[Updated on: Fri, 01 March 2024 06:53] by Moderator
Re: Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1863862 is a reply to message #1863849] Fri, 01 March 2024 09:09 Go to previous messageGo to next message
Hi, can you please prodvide a reproducer. do you have an imports for Scopes.scopeFor methods?
if yes your method might shadow that
Re: Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1863896 is a reply to message #1863862] Mon, 04 March 2024 09:01 Go to previous messageGo to next message
Scopes.scopeFor is imported, but I don't think shadowing is an issue because all calls to Scopes.scopeFor are explicit (i.e. Scopes::scopeFor).
I think it happens because one of the scopeFor dispatch methods (ex. for SpecificObject2) explicitly calls the scopeFor method for SpecificObject1, so that SpecificObject1 gets scoped without entering getScope. It's difficult to tell because I can't debug the code in Eclipse.
That's another issue. The scoper uses some utility methods written in Kotlin. I use IntelliJ for Kotlin code, but IntelliJ has no Xtext/Xtend support. But, in exchange, Eclipse has no (or very lackluster) Kotlin support. Is there some approach to debug Xtend code that uses Kotlin imports?
Re: Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1863897 is a reply to message #1863896] Mon, 04 March 2024 09:05 Go to previous messageGo to next message
Let me also provide some more context regarding the DSL:
The language itself is very simple, it consists of field and section declarations. A section can have multiple supertypes.
SectionDeclaration:
	"section" Symbol
	SectionFragment
fragment SectionFragment*:
	(":" supertype=InheritanceChain)?
		(elements+=FieldDeclaration)*
FieldDeclaration:
	Symbol
	":" type=RootExpression
	("=" assignment=RootExpression)?
InheritanceChain is a Rust-like supertype declaration (Section1 + Section2 + Section3...)
RootExpression is the root rule for expressions, symbols, literals, etc.
When a field assignment is scoped, it should also contain the fields of the supertypes of the section it is contained in.
This means
section MySection {
        foo: Int = 10
section MySectionChild : MySection {
        bar: Int = foo + 10
should be linked correctly.
How should the assignment in a FieldDeclaration be scoped? Should I check if SectionDeclaration occurs as an eContainer for the respective FieldDeclaration?
[Updated on: Mon, 04 March 2024 09:07] by Moderator
Re: Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1863898 is a reply to message #1863897] Mon, 04 March 2024 10:09 Go to previous messageGo to next message
yes you would check econtainer to end up at SectionDeclaration
then collect all supetypes and their fields + the local fields
Re: Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1864018 is a reply to message #1863898] Mon, 11 March 2024 11:22 Go to previous messageGo to next message
That means children do not inherit scopes from their containers, i.e. if I scope in the supertypes for FieldDeclaration the RootExpression in the assignment field still has to be handled by its own and respectively call scopeFor on its FieldDeclaration container?
Thanks for your helpful answers so far.
[Updated on: Mon, 11 March 2024 11:22] by Moderator
Re: Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1864027 is a reply to message #1864018] Tue, 12 March 2024 05:30 Go to previous messageGo to next message
i dont understand this question. can you please elaborate.
you are the one who implements scopes
[Updated on: Tue, 12 March 2024 05:32] by Moderator
Re: Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1865256 is a reply to message #1864027] Mon, 29 April 2024 11:05 Go to previous messageGo to next message
I had to upgrade Xtext inbetween but I am back on topic again.
Let me restate my question:
As far as I have understood it, when Xtext needs to scope an EObject, it provides the assigned scope provider with the respective EObject. My question is, is there some kind of internal "scope inheritance" done by Xtext?
Consider the example from my previous message:
section MySection {
        foo: Int = 10
        bar: Int = foo + 10
If I scope in MySection for MySectionChild, should I explicitly "append" that scope to the scope of the RootExpression ('foo + 10') in the assignment of bar, or is the scope of MySectionChild already in the scope of the bar FieldDeclaration, because MySectionChild is the eContainer of bar?
Thanks in advance for your answer.
[Updated on: Mon, 29 April 2024 11:05] by Moderator
Re: Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1865280 is a reply to message #1865256] Mon, 29 April 2024 21:12 Go to previous messageGo to next message
In this case you must collect all visible variable declarations yourself manually and then construct a scope out of it
Or nest the scope of the current section with the one of the parent section , manually
[Updated on: Mon, 29 April 2024 21:14] by Moderator
Re: Context-specific scopeFor method dispatched without entering IScopeProvider.getScope [message #1865433 is a reply to message #1865280] Fri, 03 May 2024 06:11 Go to previous message
Manually, got it, thanks for your answer.
Previous Topic:How to restrict validator to the active working file?
Next Topic:Custom Validator on Xtext Project From Existing Ecore Model
Current Time: Mon Jul 21 13:56:34 EDT 2025
Powered by FUDForum. Page generated in 0.07995 seconds
