Home » Eclipse Projects » Eclipse Scout » Server/Ui-Session List and the Upcoming Release
Server/Ui-Session List and the Upcoming Release [message #1863649] Mon, 19 February 2024 03:50 Go to next message
Hi there,
I am looking forward to the upcoming release and the docker build.
Currently we are using tomcat based docker images and include the war file (server and ui combined) and the tomcat manager application. We use the manager application to monitor the active sessions of the applications. Some time ago I wondered if we could use Jetty instead, but I found out that Jetty does not provide a list of sessions since at least version 9.4 (https://stackoverflow.com/questions/54398968/embedded-jetty-display-all-sessions-in-context).
I know there is an org.eclipse.scout.rt.server.admin.html.view.SessionsView, but the list of sessions is always empty, both in dev mode with Jetty and in production with tomcat. Am I missing a setting to enable session tracking in scout or is there another way to get the list of sessions since with the new release and the docker build I can't use the manager application anymore?
Thanks.
Nils
Re: Server/Ui-Session List and the Upcoming Release [message #1863650 is a reply to message #1863649] Mon, 19 February 2024 04:19 Go to previous messageGo to next message
I just tried with the Scout Contacts demo application; running locally (with Jetty) I can access http://localhost:8080/process enable the monitor there (second line) and after I've clicked around in the application (URL: http://localhost:8082/) I am able to see my session in the sessions view: http://localhost:8080/process?actionId=tab.SessionsView
[Updated on: Mon, 19 February 2024 04:20] by Moderator
Re: Server/Ui-Session List and the Upcoming Release [message #1863653 is a reply to message #1863650] Mon, 19 February 2024 05:36 Go to previous messageGo to next message
Hi Matthias,
Thanks for your quick reply. And you are right, in the contacts application I can also see the sessions. That is when I start server.app.dev and ui.html.app.dev. When I start all.app.dev, I don't even have the servlet responding to /process.
Of course, we don't need it when using the org.eclipse.scout.rt.serverbridge. That it is present in our applications is because I kept it in the web.xml.
Is it still correct that when using client and server, there are always 2 sessions for a client, 1 client session and 1 server session, as mentioned in this post?
When using the server bridge, there is only 1 session, the client session that is not listed in the /process session list and if I want to have such a list, I have to implement something similar for the client session?
Best regards
Nils
[Updated on: Mon, 19 February 2024 07:41] by Moderator
Re: Server/Ui-Session List and the Upcoming Release [message #1863709 is a reply to message #1863653] Thu, 22 February 2024 03:34 Go to previous messageGo to next message
Hi Nils
With the server bridge there is only one HTTP session - that's the whole point. There is still a separate IClientSession and IServerSession, because they provide different features and are kind of hard-wired into the application. The only difference is that the context switch does not happen via HTTP call (service tunnel). See the implementation in BridgeToServerBeanDecorator#ensureRunInServerContext.
To get a list of active client sessions, you could create your own little registry (just an @ApplicationScoped bean with a list). Each client session can then be registered in the execLoad() method and unregistered again in the execStore() method.
The admin interface on /process is a little bit old fashioned and not very flexible. I wouldn't rely too much on it.
Kind regards,
Beat
Re: Server/Ui-Session List and the Upcoming Release [message #1863724 is a reply to message #1863709] Fri, 23 February 2024 06:19 Go to previous messageGo to next message
Hi there,
just for the sake of completeness, Scout offers further monitoring possibilities:
MBeans
There are some @MXBean available providing information about the number of sessions (http, ui, client server) and a few other metrics.
You can use jconsole, that is included in the JDK, to show that information.
index.php/fa/43998/0/
Open Telemetry
Recently we have added basic support for Open Telemetry. To enable it, please follow the steps described in the Observability chapter. You can then use tools like Grafana to monitor your app.
  • Attachment: jconsole.png
    (Size: 53.07KB, Downloaded 290 times)
[Updated on: Fri, 23 February 2024 15:57] by Moderator
Re: Server/Ui-Session List and the Upcoming Release [message #1863740 is a reply to message #1863724] Fri, 23 February 2024 14:31 Go to previous messageGo to next message
Hi Beat and Claudio,
Thanks, I will look into writing the little session registry.
As for Open Telemetry, yes, I discovered it a few days ago and integrated it directly into our existing Grafana stack. :) The biggest Scout application we are developing is a frontend for a Spring Boot application. We use Promtail/Loki for log collection and aggregation for both Spring Boot and Scout, Tempo for observability in Spring Boot (along with the Scout correlation id that we pass in the REST calls), and Prometheus for metrics for Spring Boot and now the Scout application.
But right now there are only very basic jvm metrics that Scout provides, right? Is there any plan to integrate the metrics from the mentioned MBeans?
Best regards
Nils
[Updated on: Fri, 23 February 2024 14:33] by Moderator
Re: Server/Ui-Session List and the Upcoming Release [message #1863742 is a reply to message #1863740] Fri, 23 February 2024 16:08 Go to previous messageGo to next message
Sounds interesting, thanks for sharing :)
The number of sessions for each type should already be available as metrics. Unfortunately I do not know what other metrics are planned to integrate. Which ones would you like to see?
Re: Server/Ui-Session List and the Upcoming Release [message #1863751 is a reply to message #1863742] Sat, 24 February 2024 07:33 Go to previous messageGo to next message
You are right. Here is a list of those I see in Grafana in addtion to the ones by io.opentelemetry.runtime-telemetry-java8.
resource:
  attributes:
    service.instance.id: "822605ce-9284-4d0d-971a-9a1bc24c4c83"
    service.name: "scout.application.name from config.properties"
    telemetry.sdk.language: "java"
    telemetry.sdk.name: "opentelemetry"
    telemetry.sdk.version: "1.31.0"
  scopeMetrics:
    io.opentelemetry.runtime-telemetry-java8:
    scout.SqlConnectionPool:
      metrics:
        db.client.connections.wait_time:
          description: "The time it took to obtain an open connection from the pool.",
          unit: "ms",
          histogram:
            dataPoints: "count|sum|min|max|bucket",
            attributes:
              pool.name: "com.example.server.services.SqlService"
        db.client.connections.usage:
          description: "The number of connections that are currently in state described by the state attribute.",
          unit: "{connection}",
          sum:
            dataPoints:
            attributes:
              state: "idle|used"
        db.client.connections.max:
          description: "The maximum number of open connections allowed."
          sum:
            dataPoints:
            attributes:
  org.eclipse.scout.rt.shared.session.SessionMetricsHelper:
    metrics:
      scout.sessions.created:
        description: "The number of sessions that has been created since server start.",
        unit: "{session}",
        sum:
          dataPoints:
          attributes:
            type: "ui|client|server|http"
        isMonotonic: true
      scout.sessions.active:
        description: "The number of active sessions."
        unit: "{session}"
        sum:
          dataPoints:
          attributes:
Re: Server/Ui-Session List and the Upcoming Release [message #1864002 is a reply to message #1863649] Mon, 11 March 2024 06:00 Go to previous messageGo to next message
Hi Nils,
I see that you have identified the metrics provided by Scout. These can already be a replacement for the MBeans mentioned. Additionally the OpenTelemetry implementation also provides database connection pool metrics.
Are you missing something?
How did you get this nice yaml representation of the provided metrics?
In the future, we plan to support tracing based on OpenTelemetry (see current state of observability).
Re: Server/Ui-Session List and the Upcoming Release [message #1864485 is a reply to message #1864002] Tue, 19 March 2024 09:36 Go to previous message
Hello Bruno,
yes, but I also looked into the MBeans mentioned by Claudio and the session registry suggested by Beat.
Now I have a service running in the client module that provides tabular data, with the necessary information and the ability to terminate a session. I have tried to integrate the 'scout.diagnostics.httpSessionIdLogMode' setting, but the helper class is in the server module and is not accessible to the service.
@ApplicationScoped
public class SessionManagementService implements IGlobalSessionListener {
  private static final Logger LOG = LoggerFactory.getLogger(SessionManagementService.class);
  private final MBeanServer mBeanServer;
  private final Map<String, WeakReference<ClientSession>> clientSessions;
  private final Map<String, WeakReference<ISession>> serverSessions;
  public SessionManagementService() {
    mBeanServer = ManagementFactory.getPlatformMBeanServer();
    clientSessions = new WeakHashMap<>();
    serverSessions = new WeakHashMap<>();
  public SessionTablePageData getSessionTableData() {
    if (!ACCESS.check(new ReadSessionPermission())) {
      throw new VetoException(TEXTS.get("AuthorizationFailed"));
    ObjectName sessions = MBeanUtility.toJmxName("org.eclipse.scout.rt.ui.html", "Sessions");
    SessionTablePageData sessionTablePageData = new SessionTablePageData();
    try {
      Object sessionDetails = mBeanServer.getAttribute(sessions, "SessionDetails");
      if (sessionDetails instanceof CompositeData[] compositeDataArray) {
        var sessionRows = Arrays.stream(compositeDataArray).map(this::createSessionTableRow).toArray(SessionTableRowData[]::new);
        sessionTablePageData.setRows(sessionRows);
    } catch (MBeanException | AttributeNotFoundException | InstanceNotFoundException | ReflectionException e) {
      LOG.error("Error while querying MBean", e);
      throw new VetoException(TEXTS.get("mgmt.sessions.error.mbean", e.getClass().getSimpleName(), e.getMessage()));
    return sessionTablePageData;
  private SessionTableRowData createSessionTableRow(CompositeData compositeData) {
    var clientSessionId = compositeData.get("clientSessionId") instanceof String clientSessionIdString ? clientSessionIdString : "";
    var clientState = compositeData.get("clientState") instanceof String clientStateString ? clientStateString : "";
    var userId = compositeData.get("userId") instanceof String userIdString ? userIdString : "";
    var ageInSeconds = compositeData.get("ageInSeconds") instanceof Long ageInSecondsLong ? ageInSecondsLong : 0L;
    var httpSessionId = compositeData.get("httpSessionId") instanceof String httpSessionIdString ? httpSessionIdString : "";
    var lastAccessed = compositeData.get("lastAccessed") instanceof Date lastAccessedLong ? lastAccessedLong : null;
    var uiSessionId = compositeData.get("uiSessionId") instanceof String uiSessionIdString ? uiSessionIdString : "";
    var uiState = compositeData.get("uiState") instanceof String uiStateString ? uiStateString : "";
    SessionTableRowData row = new SessionTableRowData();
    row.setClientSessionId(clientSessionId);
    row.setClientState(clientState);
    row.setUserId(userId);
    row.setAgeInSeconds(ageInSeconds);
    row.setHttpSessionId(httpSessionId);
    row.setLastAccessed(lastAccessed);
    row.setUiSessionId(uiSessionId);
    row.setUiState(uiState);
    var userAgent = findUserAgent(clientSessionId);
    row.setUserAgent(userAgent);
    return row;
  private String findUserAgent(String clientSessionId) {
    if (clientSessions.containsKey(clientSessionId)) {
      var clientSession = clientSessions.get(clientSessionId).get();
      if (clientSession != null) {
        return clientSession.getUserAgent().toString();
    return "Unknown";
  public void terminateSession(String clientSessionId) {
    if (!ACCESS.check(new DeleteSessionPermission())) {
    if (clientSessionId == null || clientSessionId.isBlank()) {
      return;
    var clientSessionWeakReference = clientSessions.get(clientSessionId);
    if (clientSessionWeakReference == null) {
      return;
    IClientSession clientSession = clientSessionWeakReference.get();
    if (clientSession == null) {
      return;
    BEANS.get(ClientSessionStopHelper.class).scheduleStop(clientSession, true, "Kicked by admin.");
  protected void registerClientSession(ClientSession session) {
    clientSessions.put(session.getId(), new WeakReference<>(session));
  protected void unregisterClientSession(ClientSession session) {
    clientSessions.remove(session.getId());
  protected void registerServerSession(ISession session) {
    serverSessions.put(session.getId(), new WeakReference<>(session));
  protected void unregisterServerSession(ISession session) {
    serverSessions.remove(session.getId());
  public void sessionChanged(SessionEvent event) {
    if (event.getSource() instanceof ClientSession clientSession) {
      if (event.getType() == SessionEvent.TYPE_STARTED) {
        registerClientSession(clientSession);
      if (event.getType() == SessionEvent.TYPE_STOPPED) {
        unregisterClientSession(clientSession);
    } else if (!(event instanceof IClientSession) && event.getSource() != null) {
      var serverSession = event.getSource();
        registerServerSession(serverSession);
        unregisterServerSession(serverSession);
With the metrics, I copied the logged metrics from the OtlpJsonLoggingMetricExporter. ChatGPT can help with the "aggregated summary", e.g. by asking:
Please create a human readable yaml file with a summary of the attached json metrics file.
The summary should contain 2 blocks, the resource_attributes and the scopes. The scopes block should contain a block for each scope, which should contain a list of metrics within the scope. Use the canonical path of the metric as the key and a list of the names of the underlying attributes. Please omit the actual metric values and time and only specify the data type of the value. Add the description and the unit of the metric, if available. If there are only 10 or fewer possible values for an attribute, please list them as 1 string, divided by the pipe symbol. You can shorten the output for the standard scope: "io.opentelemetry.runtime-telemetry-java8".
The output varies depending on the mood of the chatbot, it seems. Sometimes it works, sometimes it doesn't
Previous Topic:We are happy to announce the release of Eclipse Scout 24.1!
Next Topic:[Solved] Session quirks - User loading session meant for someone else in the UI
Current Time: Tue Jul 22 02:18:05 EDT 2025
Powered by FUDForum. Page generated in 0.07105 seconds
