Component diagram bug? [message #1863448] |
Fri, 02 February 2024 18:48  |
How can I create a connection between two components? I am using the Papyrus 2023-03 and I try it with Papyrus 2023-12. But the behaviour is the same.
I try to use the "Connector" link between two components and two ports included in different componets. But they aren't working. If I select the connector, I can start the link only from a port but the other endpoint isn't able to be anything. Therefore I cannot create a Connector link.
And the other thing that I realized, I can't create an interface realization link between a port and an interface.
As the UML 2.5.1 specification these are valid states. What do you think, My understanding is wrong, or this is a bug?
Thank you in advance for your answers.
FUDForum. Page generated in 0.05104 seconds
