Home » Eclipse Projects » Remote Application Platform (RAP) » Deploy war on Tomcat(MANIFEST javax.servlet problem)
Deploy war on Tomcat [message #1803300] Tue, 26 February 2019 09:24 Go to next message
Currently, I made a specification language and associated software system program in RAP, it works really nice while running with Eclipse IDE.
However, I want to deploy it on the Tomcat Server.
I used Libra War Tool to export the project from Eclipse IDE to war file and deploy it on the server. but it always show :
HTTP Status 404 Not Found
Type Status Report
Message ProxyServlet: /
Description The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.
I did not know what's the problem with this.
Therefore, I decide to try the deployment with the "hello world" RAP program.
The "hello world" program works good, but once I put "javax.servlet" in the imported packages inside the MANIFEST file, then it does not work, it shows the "HTTP Status 404 Not Found" which I was mentioned.
I did follow the developer guide here:
https://www.eclipse.org/rap/developers-guide/devguide.php?topic=deployment.html
It says:
Make sure that the WAR does not contain the javax.servlet bundle. In the plug-in manifest the javax.servlet must be listed in the Import-Package section, not in Require-Bundle.
I have no idea in which part I did wrong.
Following is the code of the related file:
MANIFEST.MF
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Helloworld
Bundle-SymbolicName: helloworld
Bundle-Version: 1.0.0.qualifier
Automatic-Module-Name: helloworld
Bundle-RequiredExecutionEnvironment: JavaSE-1.8
Require-Bundle: org.eclipse.rap.rwt;bundle-version="[3.0.0,4.0.0)"
Service-Component: OSGI-INF/contribution.xml
Bundle-ClassPath: .
Import-Package: javax.servlet;version="3.1.0"
helloworld.launch
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.rap.ui.launch.RAPLauncher">
<booleanAttribute key="append.args" value="true"/>
<booleanAttribute key="askclear" value="false"/>
<booleanAttribute key="automaticAdd" value="false"/>
<booleanAttribute key="automaticValidate" value="true"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="false"/>
<booleanAttribute key="clearws" value="false"/>
<stringAttribute key="configLocation" value="${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/helloworld"/>
<booleanAttribute key="default" value="true"/>
<booleanAttribute key="default_auto_start" value="true"/>
<intAttribute key="default_start_level" value="4"/>
<booleanAttribute key="includeOptional" value="false"/>
<booleanAttribute key="org.eclipse.debug.core.appendEnvironmentVariables" value="true"/>
<stringAttribute key="org.eclipse.jdt.launching.JRE_CONTAINER" value="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.8"/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS" value="-os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl ${target.nl} -console -consolelog"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER" value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS" value="-Declipse.ignoreApp=true -Dosgi.noShutdown=true -Dorg.eclipse.equinox.http.jetty.log.stderr.threshold=info"/>
<stringAttribute key="org.eclipse.rap.launch.browserMode" value="INTERNAL"/>
<stringAttribute key="org.eclipse.rap.launch.contextpath" value="/"/>
<stringAttribute key="org.eclipse.rap.launch.dataLocation" value="${workspace_loc}/.metadata/.plugins/org.eclipse.rap.tools.launch/helloworld"/>
<booleanAttribute key="org.eclipse.rap.launch.developmentMode" value="true"/>
<booleanAttribute key="org.eclipse.rap.launch.openBrowser" value="true"/>
<intAttribute key="org.eclipse.rap.launch.port" value="10080"/>
<stringAttribute key="org.eclipse.rap.launch.servletPath" value="/hello"/>
<intAttribute key="org.eclipse.rap.launch.sessionTimeout" value="0"/>
<booleanAttribute key="org.eclipse.rap.launch.terminatePrevious" value="true"/>
<booleanAttribute key="org.eclipse.rap.launch.useDefaultDataLocation" value="true"/>
<booleanAttribute key="org.eclipse.rap.launch.useManualContextPath" value="false"/>
<booleanAttribute key="org.eclipse.rap.launch.useManualPort" value="false"/>
<booleanAttribute key="org.eclipse.rap.launch.useSessionTimeout" value="false"/>
<stringAttribute key="pde.version" value="3.3"/>
<booleanAttribute key="show_selected_only" value="true"/>
<stringAttribute key="target_bundles" value="javax.servlet@default:default,org.apache.felix.gogo.command@default:default,org.apache.felix.gogo.runtime@default:default,org.apache.felix.gogo.shell@default:default,org.apache.felix.scr,org.eclipse.equinox.console@default:default,org.eclipse.equinox.http.jetty@default:default,org.eclipse.equinox.http.servlet@default:default,org.eclipse.jetty.continuation@default:default,org.eclipse.jetty.http@default:default,org.eclipse.jetty.io@default:default,org.eclipse.jetty.security@default:default,org.eclipse.jetty.server@default:default,org.eclipse.jetty.servlet@default:default,org.eclipse.jetty.util@default:default,org.eclipse.osgi.services@default:default,org.eclipse.osgi.util@default:default,org.eclipse.osgi@-1:true,org.eclipse.rap.rwt.osgi@default:default,org.eclipse.rap.rwt@default:default"/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useCustomFeatures" value="false"/>
<booleanAttribute key="useDefaultConfigArea" value="true"/>
<stringAttribute key="workspace_bundles" value="helloworld"/>
</launchConfiguration>
build.properties
source.. = src/
output.. = bin/
bin.includes = META-INF/,\
               OSGI-INF/,\
Re: Deploy war on Tomcat [message #1806641 is a reply to message #1803300] Mon, 13 May 2019 02:13 Go to previous messageGo to next message
I had the same problem and sent a post few days ago.
The problem is how the package version is managed.
The reply of my post was to migrate to RAP 3.8.1 and it has solved the problem.
Re: Deploy war on Tomcat [message #1860399 is a reply to message #1806641] Thu, 03 August 2023 03:16 Go to previous messageGo to next message
How to deploy BIRT viewer 4.13 in the Tomcat-10
03-Aug-2023 11:31:49.000 INFO [http-nio-9999-exec-3] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive [E:\software\server\apache-tomcat-10.0.10\webapps\birt.war] has finished in [15,287] ms 03-Aug-2023 11:32:23.374 SEVERE [http-nio-9999-exec-9] org.apache.catalina.core.StandardContext.startInternal One or more Filters failed to start. Full details will be found in the appropriate container log file 03-Aug-2023 11:32:23.374 SEVERE [http-nio-9999-exec-9] org.apache.catalina.core.StandardContext.startInternal Context [/birt] startup failed due to previous errors 03-Aug-2023 11:32:36.793 SEVERE [http-nio-9999-exec-4] org.apache.catalina.core.StandardContext.startInternal One or more Filters failed to start. Full details will be found in the appropriate container log file 03-Aug-2023 11:32:36.793 SEVERE [http-nio-9999-exec-4] org.apache.catalina.core.StandardContext.startInternal Context [/birt] startup failed due to previous errors
I am founing these error.
BIRT viewer 4.13 deployment procedure for tomcat 10
Re: Deploy war on Tomcat [message #1860486 is a reply to message #1860399] Wed, 09 August 2023 09:46 Go to previous messageGo to next message
Tomcat 10.x is using Jakarta Servlet API 5/6 with jakarta namespace. Please use Tomcat 9.x with RAP.
Ivan
Re: Deploy war on Tomcat [message #1863388 is a reply to message #1860486] Tue, 30 January 2024 20:42 Go to previous message
If you want to use Apache Tomcat 10.1.x, you might want to consider the following.
https://tomcat.apache.org/download-migration.cgi
We are in service using this.
Previous Topic:RAP Menu should close when clicking on Browser
Next Topic:Dockerfile for RAP deployment
Current Time: Mon Jul 21 11:29:13 EDT 2025
Powered by FUDForum. Page generated in 0.06028 seconds
