| Download setup-file from GitLab [message #1863355] |
Mon, 29 January 2024 06:12  |
I'm trying to get a setup file using GitLab API https://docs.gitlab.com/ee/api/repository_files.html
And I use such an URL:
https://gitlab.example.com/api/v4/projects/[project_id]/repository/files/[path_to_setup_file]/raw?private_token=[token]
The setup file can be successfully downloaded, but Eclipse Installer throws the exception:
java.lang.ClassCastException: class org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl cannot be cast to class org.eclipse.oomph.base.util.BaseResource (org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @58dea0a5; org.eclipse.oomph.base.util.BaseResource is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @7446d8d5)
at org.eclipse.oomph.base.util.BaseUtil.loadResourceSafely(BaseUtil.java:97)
at org.eclipse.oomph.setup.internal.installer.ProductPage$AddUserProductDialog.processResources(ProductPage.java:2073)
at org.eclipse.emf.common.ui.dialogs.ResourceDialog.okPressed(ResourceDialog.java:372)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:468)
at org.eclipse.jface.dialogs.Dialog.lambda$0(Dialog.java:619)
at org.eclipse.swt.events.SelectionListener$1.widgetSelected(SelectionListener.java:84)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:252)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5854)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1529)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:5064)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4516)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:823)
at org.eclipse.jface.window.Window.open(Window.java:799)
at org.eclipse.oomph.setup.internal.installer.ProductPage$15.widgetSelected(ProductPage.java:591)
at org.eclipse.oomph.setup.internal.installer.Installer.runEventLoop(Installer.java:359)
at org.eclipse.oomph.setup.internal.installer.InstallerDialog.show(InstallerDialog.java:434)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.run(InstallerApplication.java:295)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.start(InstallerApplication.java:401)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:208)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:651)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:588)
at org.eclipse.equinox.launcher.Main.run(Main.java:1459)
at org.eclipse.equinox.launcher.Main.main(Main.java:1432)
I guess the cause is a wrong file name - raw (because the last segment of URL is raw). The file doesn't have setup extension. Could you suggest a workaround?
FUDForum. Page generated in 0.04935 seconds
