Re: How to set multiple values for a property of a stereotype? [message #1863490 is a reply to message #1863333] |
Mon, 05 February 2024 10:02  |
When you use getAppliedStereotype() you fall back on the underlying Eclipse UML2 Java API rather than using the marginally specified type safe OMG navigation (prototyped and supported in the Pivot-based Eclipse OCL but not in the Classic Eclipse OCL used by Acceleo).
The non-typesafe navigation is particularly troublesome for non-unit multiplicities where the EList return is declared as, and so treated as, an Object, consequently it is quite possible that asSequence, created a Sequence of Sequence which at(1) only unwrapped once.
You should probably use as oclAsType to impose your better knowledge on the getAppliedStereotype() return. Or try flatten() to eliminate the ambiguity.
FUDForum. Page generated in 0.05205 seconds
