Home » Language IDEs » C / C++ IDE (CDT) » "could not be resolved" errors, but Go To Definition works!
"could not be resolved" errors, but Go To Definition works! [message #1764002] Tue, 23 May 2017 16:52 Go to next message
I've created a makefile project from Nordic example code. Since this is a makefile project from a known source, I'm not getting build errors. I've also set up indexing properly AFAIK, having double checked many things (and see below).
But I'm getting errors in the Problems windows and red lines in the editor, stemming from numerous "could not be resolved" occurrences. The weird thing is when I click on one of the offending items (often just a simple #define constant), the IDE dutifully takes me to the definition. So one part of Eclipse understands what is going on and is resolving symbols, but another part of Eclipse does not. And none of this has anything to do with build errors, because the make based build runs with no errors.
How in tarnation do I figure out what is going on here?
- Andy
Re: "could not be resolved" errors, but Go To Definition works! [message #1764005 is a reply to message #1764002] Tue, 23 May 2017 16:59 Go to previous messageGo to next message
I just discovered that the errors are all symbol resolutions errors of the code analyzer. This maybe explains why Go To Definition works - it isn't part of the code analyzer.
Is the code analyzer maybe just not that good?
Re: "could not be resolved" errors, but Go To Definition works! [message #1764770 is a reply to message #1764005] Fri, 02 June 2017 03:55 Go to previous messageGo to next message
Hi Andy,
I have been using Eclipse for 2 days now, so be aware of my advice :+) I had the same problems, and eventually managed to figure them out.
Are you aware of setting the compiler options in 2 places?
Hopefully you have already set Properties -> C/C++ Build -> Settings -> Tool Settings -> GCC C++ Compiler -> Dialect to -std=c++14 or whatever.
To get the Indexer to work, one has to:
Select Window->Properties -> C/C++ General -> Preprocessor Include Paths, Marcos etc. -> Providers Tab
then select your compiler: CDT GCC Built-in Compiler Settings
In Command to get compiler options text box , put -std=c++1z or whatever at the end of what is there already, other compiler options can be added here too.
So all this enables the Indexer to correctly diagnose syntax problems and display them in the code window. In this case it should hopefully take away all the misdiagnosed problems.
Regards :+)
Re: "could not be resolved" errors, but Go To Definition works! [message #1784934 is a reply to message #1764770] Fri, 06 April 2018 01:13 Go to previous messageGo to next message
Thanks David,
It resolved my problem..
Re: "could not be resolved" errors, but Go To Definition works! [message #1804236 is a reply to message #1764002] Wed, 20 March 2019 23:52 Go to previous messageGo to next message
I meet the same problem, and you can try to restart eclipse:
File->Restart
And the problem has disappeared, it is amazing.
Re: "could not be resolved" errors, but Go To Definition works! [message #1862385 is a reply to message #1764770] Thu, 30 November 2023 07:29 Go to previous messageGo to next message
I still have this problem with Eclipse 2023-09.
My Eclipse does not have the Preferences settings mentioned in the "solution" above.
Re: "could not be resolved" errors, but Go To Definition works! [message #1862560 is a reply to message #1862385] Mon, 11 December 2023 23:35 Go to previous messageGo to next message
Andy, your issue with "could not be resolved" errors despite a successful build and proper indexing seems odd. Try these steps:
Re-index the project.
Check include paths and Makefile targets.
Disable CDT indexer optimization.
Clean and rebuild the project.
Use the "Go to Definition" feature.
If these don't work, investigate specific errors or explore community resources.
Re: "could not be resolved" errors, but Go To Definition works! [message #1862562 is a reply to message #1862385] Tue, 12 December 2023 00:13 Go to previous messageGo to next message
Perhaps you're using an outdated release?
Re: "could not be resolved" errors, but Go To Definition works! [message #1862604 is a reply to message #1862560] Wed, 13 December 2023 13:44 Go to previous messageGo to next message
Hi All,
I downloaded the example code for std::unordered_set. It compiles ok but still the indexing doesn't appear to work after following all your advices.
Attached is a screenshot of the code in Eclipse Version: 2023-09 (4.29.0) Build id: 20230907-1323
Is there a definitive solution to this issue?
Thanks a lot
Re: "could not be resolved" errors, but Go To Definition works! [message #1862855 is a reply to message #1862604] Wed, 03 January 2024 02:16 Go to previous messageGo to next message
Exactly the same issue occurs to me, and you may want to try restarting Eclipse: doodle jump
[Updated on: Thu, 04 January 2024 03:56] by Moderator
Re: "could not be resolved" errors, but Go To Definition works! [message #1863100 is a reply to message #1862855] Tue, 16 January 2024 04:35 Go to previous messageGo to next message
The problem stems from Eclipse not properly indexing the Makefile itself, which means it can't correctly resolve symbols that are defined in the Makefile.
To resolve this issue, you can try the following steps:
Rebuild the Index: Eclipse periodically rebuilds its index in the background. To force a rebuild, go to Project > Clean > Clean Project.
Incremental builds can help Eclipse keep the index up-to-date with changes made to the project. To enable incremental builds, go to Project > Properties > Build Automatically and check the Enable Incremental Build checkbox.
If the previous steps don't work, you can manually update the index for the Makefile file. Right-click on the Makefile file and select Refresh.
If none of the above steps work, you can try clearing the index and reindexing the project. To do this, go to Project > Clean > Clean Project and then select Clean index. This will remove the current index and force Eclipse to rebuild it from scratch.
After following these steps, the indexing issue should be resolved, and the "could not be resolved" errors should disappear.
Re: "could not be resolved" errors, but Go To Definition works! [message #1863495 is a reply to message #1862855] Tue, 06 February 2024 07:47 Go to previous message
Go to Project > C/C++ Index > Rebuild. This will rebuild the index for your project, which might resolve the issues related to symbol resolution.
snaptik
[Updated on: Tue, 06 February 2024 07:48] by Moderator
Previous Topic:Please help me compile on Mac!!???
Next Topic:GDB Hardware Debugging
Current Time: Wed Jul 30 14:21:48 EDT 2025
Powered by FUDForum. Page generated in 0.05152 seconds
