Home » Modeling » Papyrus » Papyrus as a Maven artifact?
Papyrus as a Maven artifact? [message #1862966] Mon, 08 January 2024 17:41 Go to next message
Have the Papyrus team by chance considered again the opportunity of publishing Papyrus as a library that Java developers can use easily in projects unrelated to Eclipse (that is, as a Maven artifact)?
(I am sorry to bother if things have not changed as I have asked this question already, but it's now almost three years ago and Maven central is more than ever the de-facto standard for open source artifacts, and Eclipse is slightly losing market shares among Java developers, so I have some hope that the position of the team could have since evolved in order to extend its user basis.)
Re: Papyrus as a Maven artifact? [message #1862976 is a reply to message #1862966] Tue, 09 January 2024 10:08 Go to previous messageGo to next message
I guess the answer will be the same as almost 3 years ago.
BTW, what do you want to achieve?
Re: Papyrus as a Maven artifact? [message #1862981 is a reply to message #1862976] Tue, 09 January 2024 14:38 Go to previous messageGo to next message
Thanks for the reply!
I would like to create a small Java program that uses Papyrus as a library to manipulate UML model files; similar to the way a program can use an SVG library to draw stuff, or a spreadsheet library to manipulate ODS or XLSX files.
Re: Papyrus as a Maven artifact? [message #1863050 is a reply to message #1862981] Fri, 12 January 2024 11:09 Go to previous messageGo to next message
Dear Olivier,
as you mention that you use Papyrus to "draw", do use the Papyrus diagrams (i.e. not only the semantic UML model) and manipulate the view model programmatically? We published maven artifacts for the Papyrus extension SW designer in [1], but the artifacts are already a bit old. We are reluctant to do that for the main Papyrus project, as it it might imply additional maintenant effort.
Best
Ansgar
[1] https://repo.eclipse.org/content/repositories/papyrus-releases/org/eclipse/papyrus/designer/
Re: Papyrus as a Maven artifact? [message #1863053 is a reply to message #1863050] Fri, 12 January 2024 12:23 Go to previous message
Having a proper UML model (out of which the drawings are derived) is a crucial part of my reasons to use Papyrus rather than any one of the numerous APIs out there to draw UML diagrams. I appreciate that Papyrus takes UML seriously by defining models, not just circles and boxes.
(I mentioned drawing just to make a parallel to any other use of an API to obtain results, whether graphical or different.)
[Updated on: Fri, 12 January 2024 12:24] by Moderator
Previous Topic:Custom architecture contexts/viewpoints don't work
Next Topic:2023-12 release?
Current Time: Mon Jul 21 12:50:14 EDT 2025
Powered by FUDForum. Page generated in 0.06333 seconds
