Home » Eclipse Projects » e(fx)clipse » efxclipse 3.x and the path to 4.0
efxclipse 3.x and the path to 4.0 [message #1855085] Wed, 28 September 2022 03:51 Go to next message
The following is only important for those consuming the runtime of e(fx)clipse.
We think it is now the time to think about the next steps for e(fx)clipse and we want to layout out what we (BestSolution who does most of the work) think is best for the future of the project.
We've already started a long time ago an effort remove PDE/maven-tycho from the runtime (build) and make our projects PURE maven artifacts. After the release of e(fx)clipse 3.9 we will concentrate on moving this forward which is going to be easier (as it used to be) because the Eclipse Platform releases all its bits to maven-central since some time.
The plan for the main-branch looks like this:
- Merge the latest changes from 3.x-branch to master
- Restructure the projects (eg split projects, ...)
- Remove Java-8 support
We will still provide a target platform so you can still use Eclipse-PDE for development but our main target will be pure maven.
Re: efxclipse 3.x and the path to 4.0 [message #1855415 is a reply to message #1855085] Wed, 12 October 2022 23:03 Go to previous messageGo to next message
That sounds awesome. Happy to help out with testing, sample projects etc.
Re: efxclipse 3.x and the path to 4.0 [message #1858100 is a reply to message #1855415] Wed, 15 March 2023 18:29 Go to previous messageGo to next message
Any progress on this? I am very keen to convert to maven-only config for my projects.
Re: efxclipse 3.x and the path to 4.0 [message #1862710 is a reply to message #1855085] Thu, 21 December 2023 16:28 Go to previous messageGo to next message
Hi tom,
Any news about efxclipse 4.0 ?
I canotn see in runtime binary repos any new update site apart from official releases ?
Last is 3.9 you built before starting 4.0 stream dev.
Stéphane
Thomas Schindl wrote on Wed, 28 September 2022 09:51
Re: efxclipse 3.x and the path to 4.0 [message #1862920 is a reply to message #1862710] Sat, 06 January 2024 05:19 Go to previous messageGo to next message
Sorry for my silence but I've been overwhelmed by company work (mainly TS) - I just today started downloading the latest Version of Eclipse and started updating the code. So for the runtime I guess I need to do a release based on PDE and not follow my initial plan to provide a maven based version.
Re: efxclipse 3.x and the path to 4.0 [message #1863256 is a reply to message #1862920] Fri, 19 January 2024 14:22 Go to previous messageGo to next message
Thomas Schindl wrote on Sat, 06 January 2024 11:19
Hi Tom,
Thanks for the update.
I will be pleased to test and provide you with feedbacks.
Which version of JavaFX will you use to compile efx runtime please ?
Stéphane.
Re: efxclipse 3.x and the path to 4.0 [message #1865943 is a reply to message #1855085] Wed, 15 May 2024 15:44 Go to previous message
Hi Tom,
any news about an efxclipse update.
Best regards
Dominik
Previous Topic:Unable to create New FXML Document and error build.fxbuild
Next Topic:Setup a JavaFx configuration for JDK 17 and the last version of Eclipse
Current Time: Wed Nov 05 16:39:50 EST 2025
Powered by FUDForum. Page generated in 0.05147 seconds
