Home » Eclipse Projects » EclipseLink » delete operation not happening in child object for relationship mapping(delete operation not happening in child object)
delete operation not happening in child object for relationship mapping [message #1862701] Thu, 21 December 2023 08:49 Go to next message
Hi Team,
As a part of migration from toplink to eclipselink , we have a case where entity in child mapping is deleted and later merge is called on parent object .Commit happens after this and can see child object is not deleted from database .
When looked into the issue , parent object still holds child in list and merges it .
please find the mapping below:
Mapping in parent table:
<attribute-mapping xsi:type="one-to-many-mapping">
<attribute-name>child</attribute-name>
<reference-class>de.*.*.*..impl.child</reference-class>
<private-owned>true</private-owned>
<cascade-persist>true</cascade-persist>
<target-foreign-key>
<field-reference>
<source-field table="child" name="MIG_ID" xsi:type="column"/>
<target-field table="Parent" name="ID" xsi:type="column"/>
</field-reference>
</target-foreign-key>
<container xsi:type="list-container-policy">
<collection-type>org.eclipse.persistence.indirection.IndirectList</collection-type>
</container>
<indirection xsi:type="transparent-collection-indirection-policy"/>
<selection-query xsi:type="read-all-query">
</container>
</selection-query>
</attribute-mapping>
mapping in child table
<attribute-mapping xsi:type="one-to-one-mapping">
<attribute-name>migranten</attribute-name>
<reference-class>de.*.*.*.impl.MigrantenImpl</reference-class><cascade-persist>true</cascade-persist>
<foreign-key>
<field-reference>
<target-field table="parent" name="ID" xsi:type="column"/>
</field-reference>
</foreign-key>
<foreign-key-fields>
<field table="child" name="MIG_ID" xsi:type="column"/>
</foreign-key-fields>
<indirection xsi:type="value-holder-indirection-policy"/>
<selection-query xsi:type="read-object-query"/>
I see same happens in toplink(same mapping configuration) but it delets the child object . Could you please let me know if am missing something .
Sanjana
[Updated on: Thu, 21 December 2023 08:50] by Moderator
Re: delete operation not happening in child object for relationship mapping [message #1862752 is a reply to message #1862701] Wed, 27 December 2023 11:14 Go to previous messageGo to next message
This is expected behavior, and I would consider it a bug in the earlier TopLink code base. Merging in an entity with references to a previously deleted entity should always be expected to undo or insert the previously deleted child entity.
Best option is always to fix/null all references to objects you are deleting and ensure all cached references are cleaned up.
Re: delete operation not happening in child object for relationship mapping [message #1862773 is a reply to message #1862752] Fri, 29 December 2023 00:49 Go to previous message
Thanks Chris for the reply .
Previous Topic:Embedded Persistence Issue
Next Topic:Deletion of entity throwing foreign key constraint for unidirectional mapping
Current Time: Thu Sep 18 11:13:12 EDT 2025
Powered by FUDForum. Page generated in 0.28967 seconds
