Re: Papyrus does not give an option to select SysML as a modeling language on a new project [message #1862543 is a reply to message #1858832] |
Mon, 11 December 2023 04:17   |
I ran into the same issue. It is not fixed and "Thanks anyway" is not enough. Three screenshots are supplementing this post. For anyone entering the game with Papyrus and wishing to try SysML, it is, to say the least, confusing what is happening right from the start.
The website does not clearly indicate that SysML is not part of the package, neither does the manual/documentation point this fact out. At least this is my finding after quick look into it.
Later, once the approach is taken to install via external addon from Marketplace, which is also not mentioned clearly in documentation, it will actually depreciate UML Developer capabilities! In fact there seems to be a problem after installing/deinstalling from Marketplace, which is even beyond this posting.
If a tool, such as Papyrus, claims that is exactly for MBSE and supporting SysML, then the first thing that should work, IMHO, is SysML. This is simply a user-pov expectation that does not need to be further explained or put into rational terms.
Kind regards
Attachment: uninstall.png
(Size: 33.16KB, Downloaded 673 times)
Attachment: nosysml.png
(Size: 21.33KB, Downloaded 663 times)
Attachment: nosysml2.png
(Size: 64.08KB, Downloaded 667 times)
FUDForum. Page generated in 0.06965 seconds
