Home » Newcomers » Newcomers » Not newcomer but(Kotlin, Maven and Bug reporting problems)
Not newcomer but [message #1862577] Tue, 12 December 2023 08:09 Go to next message
It was a few years ago I worked with Eclipse and today I wanted to test Eclipse with Kotlin.
I never thought it would work, but I tried. I open then Maven project which has many nested modules and it got stuck. Finally I get the error "An internal error occured while showing an internal error"??
As I said, I never thought it would work, but this was cute.
Then I wanted to test creating a Maven project. I create it but there is an error in the pom.xml "cvc-elt.1.a: Cannot find the declaration of element 'project'."
Have you made any quality assurance?? It could not create a Maven project.
So I thought, I can be nice and file a bug. I select "Help/Report Bug or Enhancement ..." and this appeared "No support providers are available"
A cheif's kiss.
Re: Not newcomer but [message #1862580 is a reply to message #1862577] Tue, 12 December 2023 09:29 Go to previous messageGo to next message
I guess you used this:
https://marketplace.eclipse.org/content/kotlin-plugin-eclipse
and instead of going here
https://kotlinlang.org/
or here:
https://discuss.kotlinlang.org/
came to this forum. I don't think the Kotlin folks will read what you wrote here.
There are hundreds of external extensions to Eclipse, and their quality varies. :-(
You can report Maven issues here:
https://github.com/eclipse-m2e/m2e-core/issues
It would be good to provide a bit more detail...
In the end, so many projects and so many places to report problems. The help report bugs things comes from Mylyn and that appears to be effectively useless, so I opened this issue:
https://github.com/eclipse-mylyn/org.eclipse.mylyn/issues/338
Re: Not newcomer but [message #1862935 is a reply to message #1862580] Mon, 08 January 2024 04:07 Go to previous message
The issues you raise are all very reasonable.
Previous Topic:Unhandled event loop exception
Next Topic:No repository found when install plugin
Current Time: Mon Jul 21 11:44:07 EDT 2025
Powered by FUDForum. Page generated in 0.29612 seconds
