Home » Modeling » TMF (Xtext) » Creating an XText based Product
Creating an XText based Product [message #1862416] Sun, 03 December 2023 17:41 Go to next message
The XText doc on CI (https://eclipse.dev/Xtext/documentation/350_continuous_integration.html#tycho-build) has an example of how to create a feature / plugin for an XText DSL. I have not yet found an example of creating an Eclipse product for an XText DSL. Can someone point me to one? In particular, I'm trying to make sure my target.target file contains all the appropriate location / unit references needed so that the product build results in a product that will launch and work properly.
Right now, I using the approach described here:
https://www.youtube.com/watch?v=ZmUrTlzqCXc
That works for Sirius but something is missing for XText.
For my XText product, the product file contains:
<?pde version="3.5"?>
<product name="UDDL Product" uid="com.epistimis.uddl.query.product" application="org.eclipse.ui.ide.workbench" version="1.0.0.qualifier" type="mixed" includeLaunchers="true" autoIncludeRequirements="true">
   <configIni use="default">
   </configIni>
   <launcherArgs>
      <vmArgsMac>-XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts
      </vmArgsMac>
   </launcherArgs>
   <launcher name="UQ">
      <win useIco="false">
         <bmp/>
      </win>
   </launcher>
   <vm>
      <macos include="true">org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-17</macos>
   </vm>
   <plugins>
      <plugin id="com.google.inject"/>
      <plugin id="javax.inject"/>
      <plugin id="org.eclipse.xtext"/>
   </plugins>
   <features>
      <feature id="com.epistimis.uddl.query.feature" installMode="root"/>
      <feature id="org.eclipse.platform" installMode="root"/>
   </features>
   <configurations>
      <plugin id="org.apache.felix.scr" autoStart="true" startLevel="2" />
      <plugin id="org.eclipse.core.runtime" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="2" />
      <plugin id="org.eclipse.equinox.event" autoStart="true" startLevel="2" />
      <plugin id="org.eclipse.equinox.simpleconfigurator" autoStart="true" startLevel="1" />
   </configurations>
</product>
And my feature project contains:
<feature
      label="Query Feature "
      provider-name="Epistimis LLC">
   <description>
      Support for UDDL Queries.
   </description>
   <plugin
         id="com.epistimis.uddl.query"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="com.epistimis.uddl.query.ide"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
   <plugin
         id="com.epistimis.uddl.query.ui"
         download-size="0"
         install-size="0"
         version="0.0.0"
         unpack="false"/>
</feature>
I get a product that will launch. But when I try to create a new project based on my DSL, I get:
Failed to create injector for com.epistimis.uddl.query.Query (occurred in com.epistimis.uddl.query.ui.QueryExecutableExtensionFactory)
[Updated on: Sun, 03 December 2023 19:48] by Moderator
Re: Creating an XText based Product [message #1862417 is a reply to message #1862416] Sun, 03 December 2023 23:52 Go to previous messageGo to next message
Can you provide the actual error. (the other end of the stacktrace, missing dependencies reported in the log file etc)
besides that did not test if this one is still running
https://github.com/cdietrich/xtext-maven-example/blob/master/org.xtext.example.mydsl.product/org.xtext.example.mydsl.product.product
[Updated on: Mon, 04 December 2023 00:25] by Moderator
Re: Creating an XText based Product [message #1862419 is a reply to message #1862417] Mon, 04 December 2023 03:18 Go to previous messageGo to next message
Hello Steve!
You can also take a look at the product file of this Xtext-based open source project to get some inspiration and compare it with your product file to identify the shortcomings:
https://github.com/itemis/MBSE4ME/blob/main/com.itemis.mbse4me.dsls.product/mbse4me.product
Hope that helps!
Tamás
Re: Creating an XText based Product [message #1862427 is a reply to message #1862419] Mon, 04 December 2023 11:29 Go to previous messageGo to next message
Thanks for the product references. I'll check out both of them.
There is no log file or stacktrace that I can see. Nothing shows up in the console windlow or Error Log window - or in the .metadata directory. Whatever is happening happens as soon as I try to create a new DSL project.
Here's the content of my .metadata./.plugins directory in the workspace I'm using:
total 0
drwxr-xr-x@ 3 stevehickman  staff   96 Dec  3 16:47 com.epistimis.uddl.query.ui
drwxr-xr-x@ 5 stevehickman  staff  160 Dec  3 16:47 org.eclipse.core.resources
drwxr-xr-x@ 3 stevehickman  staff   96 Dec  3 16:47 org.eclipse.core.runtime
drwxr-xr-x@ 2 stevehickman  staff   64 Dec  3 16:46 org.eclipse.debug.core
drwxr-xr-x@ 2 stevehickman  staff   64 Dec  4 08:15 org.eclipse.debug.ui
drwxr-xr-x@ 2 stevehickman  staff   64 Dec  4 08:15 org.eclipse.e4.ui.workbench.swt
drwxr-xr-x@ 3 stevehickman  staff   96 Dec  3 16:47 org.eclipse.e4.workbench
drwxr-xr-x@ 2 stevehickman  staff   64 Dec  3 18:30 org.eclipse.emf.common.ui
drwxr-xr-x@ 7 stevehickman  staff  224 Dec  3 16:47 org.eclipse.jdt.core
drwxr-xr-x@ 4 stevehickman  staff  128 Dec  3 16:47 org.eclipse.jdt.ui
drwxr-xr-x@ 3 stevehickman  staff   96 Dec  3 16:47 org.eclipse.ui.ide
drwxr-xr-x@ 2 stevehickman  staff   64 Dec  4 08:18 org.eclipse.ui.views.log
drwxr-xr-x@ 3 stevehickman  staff   96 Dec  3 16:47 org.eclipse.ui.workbench
drwxr-xr-x@ 2 stevehickman  staff   64 Dec  4 08:15 org.eclipse.xtext.builder
and the content of the version.ini file:
#Mon Dec 04 08:14:45 PST 2023
org.eclipse.core.runtime=2
org.eclipse.platform=4.30.0.v20231115-1800
The configuration contents for the product as created is attached.
Re: Creating an XText based Product [message #1862428 is a reply to message #1862427] Mon, 04 December 2023 11:54 Go to previous messageGo to next message
i am quite sure these must be somehting in the log. maybe you can remote debug into the exception to get a stacktrace
maybe you also can try to activate from osgi console and see if there is a better error message e.g. missing dependencies
[Updated on: Mon, 04 December 2023 11:59] by Moderator
Re: Creating an XText based Product [message #1862431 is a reply to message #1862428] Mon, 04 December 2023 12:55 Go to previous messageGo to next message
Ahhh... No log or stack trace because I was trying to create a DSL project. By creating a general project and then a general file with the DSL extension, I get the stack trace as part of the file creation process.
I will pursue what's missing based on that stack trace and report back.
I suspect that creating the DSL project was a multi step process than threw away the stack trace in the middle.
[Updated on: Mon, 04 December 2023 12:57] by Moderator
Re: Creating an XText based Product [message #1862449 is a reply to message #1862431] Tue, 05 December 2023 13:07 Go to previous message
The stacktrace clarified the problem. The example provided by Tamas was a good inspiration. What I realized from that is that I should do the following:
0) Create a Product project and product file (Youtube link in original post shows you how).
1) Create a minimal Run Configuration
2) Save it to a file I can see (Open the configuration, select the Common tab, select Shared file, pick a location and the click Apply)
3) Open the Launch file created by the prior step and use the
<setEntry />
elements in the
<setAttribute key="selected_target_bundles">
element as a list of the plugins to include in the product. A copy/paste and global find/replace does that nicely.
4) Update the
target.target
file with location information. Many / Most of the plugins will be in one of the following repositories (adjusted for the release you're using):
	<repository location="https://download.eclipse.org/releases/2023-12"/>
	<repository location="https://download.eclipse.org/tools/orbit/simrel/orbit-aggregation/2023-12"/>
	<repository location="https://download.eclipse.org/oomph/simrel-orbit/milestone/latest"/>
Each of these should already have a location element in the file:
<location includeAllPlatforms="false" includeConfigurePhase="false" includeMode="planner" includeSource="true" type="InstallableUnit">
</location>
but one can be added for each repository that isn't already there.
Then it's just a matter of figuring out which unit comes from which repository. There are several ways to do that:
A) Use the repository URL to look up the contents - you should get a web page that has a list of the contents.
B) Use Ctrl-Space for Content Assist- I'll admit I was surprised that this worked but it does (I don't know why - this is Eclipse - everything gets Content Assist!). You'll only get a valid choice to complete if that unit comes from that repository. You can also select the specific version if you need to or "0.0.0" to pick the current version.
If you're doing more than just vanilla XText, you may need additional repositories depending on your particular product.
I'm attaching both my product and target.target file to this post. The particular grammar used doesn't matter. This is a basic XText product with a full Eclipse IDE - if yours is similar, the required plugins should be essentially the same as these. I believe the primary distinction between this and Christian's example is that Christian's creates an SDK but does not result in an RCP application. (He can correct me if I'm wrong on that.) The plugins specific to my grammar are in
     <feature id="com.epistimis.uddl.query.feature" /> <!-- installMode="root"/>  -->
Note that both of the attached files are still a little bit of a mess. I don't know what
 installMode="root"
is for but commenting it out didn't appear to break anything in the product. Note also that the configuration settings are *NOT* the Eclipse defaults - those are taken from Christian's example. You can test that this works using the approach from the YouTube video listed at the top.
[Updated on: Tue, 05 December 2023 13:52] by Moderator
Previous Topic:TextMate file name and location
Next Topic:Code generation from DSL
Current Time: Sun Aug 31 17:11:01 EDT 2025
Powered by FUDForum. Page generated in 0.03384 seconds
