Home » Eclipse Projects » Remote Application Platform (RAP) » equinox Servlet throw an exception during the int stage (equinox Java 17 compatibility )
equinox Servlet throw an exception during the int stage [message #1862354] Tue, 28 November 2023 04:21
I have a web application that has been tested successfully with Java 8 and Java 11, but when I try to start the Tomcat server with Java 17, it throws an exception during the initial stage of the init() method. I attempted to address the issue by updating the runtime libraries to the latest versions, including org.eclipse.core.runtime_3.29.0 and the servlet bridge org.eclipse.equinox.servletbridge_1.6.300, but the problem persists. If you have any insights or suggestions.. thanks
Attached the log
  • Attachment: eq.PNG
    (Size: 699.07KB, Downloaded 88 times)
Previous Topic:JAVA 11 compatible RAP version
Next Topic:RAP 4.26 with Eclipse RCP and RAP IDE does not find org.eclipse.swt.widgets.Display
Current Time: Mon Jul 21 11:12:11 EDT 2025
Powered by FUDForum. Page generated in 0.02839 seconds
