Home » Eclipse Projects » Paho » Paho ws disconnected when internal docker network
Paho ws disconnected when internal docker network [message #1862338] Mon, 27 November 2023 01:00
Dear community,
I am experiencing an issue with the library. Below mi config:
- docker compose running:
-- mosquitto service with name mqtt-broler and exposing 1883 and 9001 for mqtt and was respectively.
-- http application with paho client library for ws.
Both are connected at the same time to an internal docker network.
I am able to ping each container from the other by its name.
Problem:
If I connect to the broker using ws://localhost:9001/mqtt works perfectly.
If I connect to the broker using ws://mqtt-broler:9001/mqtt I get a disconnection message. It never connects.
Just for curiosity I tried with mqtt instead of ws and worked perfectly.
Could someone help me with that?
Previous Topic:Intermittent hang in Paho client when application is connecting.
Next Topic:paho client subscribe succeed, but no message received
Current Time: Mon Jul 21 10:51:01 EDT 2025
Powered by FUDForum. Page generated in 0.24824 seconds
