Home » Language IDEs » C / C++ IDE (CDT) » Ctrl click variable reference/hyperlinks, right click menu
Ctrl click variable reference/hyperlinks, right click menu [message #1862236] Mon, 20 November 2023 00:20
Hi my eclipse was several years old & buggy so I set new download links to update all components. Current version:
Eclipse IDE for C/C++ Developers
Version: 2023-09 RC1 (4.29.0 RC1)
Right click menu like open declaration, toggle header/source, search references etc all fail.
Generic Search Text works fast though.
On ctrl+click links, in C++ some variables link, functions mostly fail. Also for Python variables link, and a few functions link (often links to wrong function but at least it opens a choice popup).
I tried the workarounds in the 2 links. Also updated linuxtools to newer version that should cover the bugfix.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=517610
https://stackoverflow.com/questions/45292251/hyperlink-navigation-via-ctrlclick-in-eclipse-oxygen-does-not-work
PyDev for Eclipse 9.3.0.202203051235 org.python.pydev.feature.feature.group Fabio Zadrozny
Eclipse Linux Tools Binutils Plug-in 6.0.0.202310270558 org.eclipse.linuxtools.binutils
Header links now work, a few variables link, but functions hyperlink does nothing. Right-click Open/Toggle menus all fail still.
Some link features work if it's in the same file. C++ is unable to jump across file even on obvious pairs like main.cpp & main.hh. Python's able to jump files sometimes, but at times opens the wrong file.
Refactor Rename: broken. Still ran a slow progress bar to complete, but only renames current selection. Long ago I believe this used to work, not sure which version.
I noticed only C++ has more right click features, that Python is missing. Is there a way or Plugin to add more multi language unified refactoring/linking support?
Do I have the wrong components version? Or is my prefs/settings messed up?
Previous Topic: "Timestamp display in GDB possible?"
Next Topic:Header path correct but "File not Found"
Current Time: Mon Jul 21 08:19:10 EDT 2025
Powered by FUDForum. Page generated in 0.26561 seconds
