Home » Modeling » Papyrus » problem loading the color of all model elements(problem loading the color of all model elements when loading a big model)
problem loading the color of all model elements [message #1862157] Wed, 15 November 2023 12:20 Go to next message
index.php/fa/43715/0/
So I installed papyrus for eclipse on my 2020 mac book air that runs on ventura 13.6.
I have data models to load, and css themes to apply. Everything seems to be working just fine for most of the models, but I do have problems loading colors on every element (the elements that are not loading are at the top of the models)
=> When I check the properties, I do see the color but it doesn't show.
As you can see on the screen, some elements are half colored, so I believe it to be a loading issue. Still, I don't know how to solve it.
Can you guys help me ??
Re: problem loading the color of all model elements [message #1862158 is a reply to message #1862157] Wed, 15 November 2023 13:43 Go to previous messageGo to next message
You mentioned the hardware and operating system versions, why not the Eclipse and Papyrus versions?
Re: problem loading the color of all model elements [message #1862170 is a reply to message #1862158] Thu, 16 November 2023 03:33 Go to previous messageGo to next message
Hi Nitin,
Sorry. So I have the Version: 2023-09 (4.29.0) of eclipse and the Papyrus UML Modeller version 6.6.0.202310290300
Re: problem loading the color of all model elements [message #1862183 is a reply to message #1862170] Thu, 16 November 2023 09:30 Go to previous message
Hi Jeanne,
please could you describe more your changes to understand how you get this trouble. Could you send us your css stylesheet please ? We can't reproduce the problem on Windows.
Can you describe the problem in the right red rectangle ? Do you have message in the error log ? Did you try to do a refresh ? Do you still get the problem reopening the model/diagram ?
/Vincent
Previous Topic:Display rendering not correct on Linux
Next Topic:Installation error "cannot satisfy dependencies"
Current Time: Fri Aug 01 12:46:22 EDT 2025
Powered by FUDForum. Page generated in 0.04243 seconds
