Corrupted TEXT.nls file for French accented characters + permission not granted error on js build.sh [message #1861895] |
Fri, 10 November 2023 20:02  |
Hi there everyone,
I have built a multilanguage application by closely following the instructions given in https://eclipsescout.github.io/scout-docs/23.2/sdk/sdk-eclipse.html#sec-sdk_nls for translated text entries.
However, in the last three 3 days my TEXT.nls file becomes "corrupted" anytime I add a new entry. For example, I have the following entries in the file:
Account status
Activated
Active
Active employee
Actual state
This is how the translated entries are presented, even after I correctly typed the translations (see attachment):
�tat du compte
Activ�
En activit�
Salari� en activit�
�tat actuelle
I've deleted my project and restored from backups at least 15 times already over the last three days and each time I make the necessary changes and then try to run the application from the IDE, I notice that the TEXT.nls file is corrupted and the accented French characters are garbled.
But in the TEXTS_fr.properties file, the entries are correct !!!!!
And finally, when I try to RUN the application in the Eclipse IDE, I get a message box error that says
Exception occurred executing command line.
Cannot run program "/home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp/run-configs/js build.sh" (in directory "/home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.ui.html"): error=13, Permission non accordée
I really don't know what to do anymore, and I'm really hoping someone here can help me get to the bottom of this matter.
Thanks for your kind assistance.
JD
Programming environment: Linux Mint
Java version: 17
Eclipse version: 2023.09
Scout version: 23.2
[Updated on: Fri, 10 November 2023 20:24] by Moderator
FUDForum. Page generated in 0.08588 seconds
