Home » Modeling » EMF » Incomplete EPackage from ecore file
Incomplete EPackage from ecore file [message #1861705] Mon, 30 October 2023 04:50 Go to next message
I'm working on checking in runtime if a VQL file is syntactically correct given a metamodel.
The problem is that when I parse an ECore metamodel from file, the references and containments are missing.
val ResourceSet resourceSet = new ResourceSetImpl();
EPackage.Registry.INSTANCE.put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE)
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(
	"ecore", new EcoreResourceFactoryImpl());
val resource = resourceSet.getResource(
	URI.createFileURI("res/meta.ecore"), true);
val pkg = resource.contents.get(0) as EPackage
If I run the code above, classifiers and super types are loaded in, but none of the structural features. (eAllReferences, eAllStructuralFeatures and eAllContainments are null.)
Do you have any idea on what is the problem and how to fix it?
Máté
Re: Incomplete EPackage from ecore file [message #1861713 is a reply to message #1861705] Mon, 30 October 2023 09:20 Go to previous messageGo to next message
Always load a resource using an absolute URI, e.g., URI.createFileURI(new File("res/meta.ecore").getAbsolutePath()), otherwise relative URIs within the serialized resources cannot be properly resolved.
Re: Incomplete EPackage from ecore file [message #1861725 is a reply to message #1861713] Tue, 31 October 2023 04:18 Go to previous messageGo to next message
Thank you for the response.
There are no relative URIs in the ecore file.
metamodel:
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="satellite1" nsURI="http://www.example.org/satellite1" nsPrefix="satellite1">
  <eClassifiers xsi:type="ecore:EClass" name="ConstellationMission">
    <eStructuralFeatures xsi:type="ecore:EReference" name="groundStationNetwork" lowerBound="1"
        eType="#//GroundStationNetwork" containment="true"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="spacecraft" lowerBound="2"
        upperBound="-1" eType="#//Spacecraft" containment="true"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="CommunicatingElement">
    <eStructuralFeatures xsi:type="ecore:EReference" name="commSubsystem" lowerBound="1"
        upperBound="2" eType="#//CommSubsystem" containment="true"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="GroundStationNetwork" eSuperTypes="#//CommunicatingElement"/>
  <eClassifiers xsi:type="ecore:EClass" name="InterferometryMission" eSuperTypes="#//ConstellationMission"/>
  <eClassifiers xsi:type="ecore:EClass" name="Spacecraft" abstract="true" eSuperTypes="#//CommunicatingElement">
    <eStructuralFeatures xsi:type="ecore:EReference" name="payload" eType="#//Payload"
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="CommSubsystem" abstract="true">
    <eStructuralFeatures xsi:type="ecore:EReference" name="target" eType="#//CommSubsystem"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="fallback" eType="#//CommSubsystem"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Payload" abstract="true"/>
  <eClassifiers xsi:type="ecore:EClass" name="InterferometryPayload" eSuperTypes="#//Payload"/>
  <eClassifiers xsi:type="ecore:EClass" name="CubeSat3U" eSuperTypes="#//CubeSat"/>
  <eClassifiers xsi:type="ecore:EClass" name="CubeSat6U" eSuperTypes="#//CubeSat"/>
  <eClassifiers xsi:type="ecore:EClass" name="SmallSat" eSuperTypes="#//Spacecraft"/>
  <eClassifiers xsi:type="ecore:EClass" name="CubeSat" abstract="true" eSuperTypes="#//Spacecraft"/>
  <eClassifiers xsi:type="ecore:EClass" name="UHFCommSubsystem" eSuperTypes="#//CommSubsystem"/>
  <eClassifiers xsi:type="ecore:EClass" name="XCommSubsystem" eSuperTypes="#//CommSubsystem"/>
  <eClassifiers xsi:type="ecore:EClass" name="KaCommSubsystem" eSuperTypes="#//CommSubsystem"/>
</ecore:EPackage>
Re: Incomplete EPackage from ecore file [message #1861727 is a reply to message #1861725] Tue, 31 October 2023 05:00 Go to previous messageGo to next message
This is relative reference:
Always, always use absolute URIs, if only for for your safety and comfort.
Re: Incomplete EPackage from ecore file [message #1861729 is a reply to message #1861727] Tue, 31 October 2023 05:48 Go to previous messageGo to next message
Ok, I changed it to what you suggested, but the issue persist.
#//CommSubsystem is resolved properly in
But, in case of
</eClassifiers>
there are no entries for the structural features.
index.php/fa/43659/0/
  • Attachment: feature.PNG
    (Size: 31.69KB, Downloaded 203 times)
Re: Incomplete EPackage from ecore file [message #1861731 is a reply to message #1861729] Tue, 31 October 2023 07:05 Go to previous message
I see a containment list for eStructuralFeatures, but I don't know how you know it's empty. That's not evident from your picture. It's pretty much impossible for containment features not to be populated for a resource that loads without exceptions/errors. I can see eOperations is null (because the getter has never been called) but eStructuralFeatures is not null and I expect it contains your two features.
Previous Topic:Models partially loaded with jUnit
Next Topic:Changed behavior of Undo/Redo menu's entries?
Current Time: Sat Jul 19 20:45:51 EDT 2025
Powered by FUDForum. Page generated in 0.04363 seconds
