Replacing DiagramContributionItemProvider [message #185961] |
Fri, 09 May 2008 05:52  |
Originally posted by: Ajay.kemparaj.in.bosch.com
Hello All,
i have written a class(CustomisedDiagramContributionItemProvider)
similar to DiagramContributionItemProvider i have specified the
CustomisedDiagramContributionItemProvider class in the plugin.xml instead
of DiagramContributionItemProvider ,The
CustomisedDiagramContributionItemProvider is not called at all the control
goes to DiagramContributionItemProvider
how to specify my own DiagramContributionItemProvider ?
Ajay
Re: Replacing DiagramContributionItemProvider [message #186657 is a reply to message #186172] |
Tue, 13 May 2008 10:03   |
Originally posted by: ajay.kemparaj.in.bosch.com
Linda,
i changed the priorites and it still calls the
Am i missing anything out here
Ajay K
Ajay wrote:
> Linda,
> i changed the Priority to highest ,it Still didn't work
> Regards,
> Ajay K
Linda,
i changed the Priority to highest ,it Still didn't work Regards,
Ajay K
Ajay,
The ContributionItemService uses ExecutionStrategy.REVERSE, which means in
consults all of the providers, from lowest to highest priority. Did you
give your provider a higher priority than the
DiagramContributionItemProvider?
Linda
Ajay wrote:
Hello All,
i have written a
class(CustomisedDiagramContributionItemProvider) similar to
Ajay
Re: Replacing DiagramContributionItemProvider [message #196042 is a reply to message #186657] |
Tue, 08 July 2008 05:12  |
Originally posted by: janiko.gmx.de
Hi, i have exactly the same problem. This is very confusion. May its the
version, i work with the old 1.0.3 version. Can anyone help us?
Tony
Ajay schrieb:
> Linda,
> DiagramContributionItemProvider Am i missing anything out here
> Regards,
> Ajay K
> Ajay wrote:
>> Linda,
>> Regards,
>> Ajay K
> Linda,
> Ajay K
> Ajay,
> in consults all of the providers, from lowest to highest priority. Did
> you give your provider a higher priority than the
> Regards,
> Linda
> Ajay wrote:
> Hello All,
> i have written a
> instead of DiagramContributionItemProvider ,The
> control goes to DiagramContributionItemProvider
> Ajay
FUDForum. Page generated in 0.03475 seconds
