Home » Eclipse Projects » Eclipse Scout » Access to Diagnostic servlet(How to access tp /diagnostic servlet to monitor application ?)
Access to Diagnostic servlet [message #1861452] Fri, 13 October 2023 08:05 Go to next message
I see that the diagnostic servlet expose a meaningful informations about monitoring the application.
Can someone know how to access this diagnostic servlet (Directly accessing it from server endpoint return 404 response)?
Re: Access to Diagnostic servlet [message #1861485 is a reply to message #1861452] Mon, 16 October 2023 02:30 Go to previous messageGo to next message
To access the servlet you need to have access to your Scout backend server, e.g.
- your backend must be reachable using http (by network policies)
- the diagnostic servlet must be included in your web.xml
- your ServerServletFilter implementation needs to include an access controller which is able to authorize a user request directly in your backend server (e.g. username/password), usually this part of authenticator is only included in UI server)
Paolo
Re: Access to Diagnostic servlet [message #1861621 is a reply to message #1861485] Mon, 23 October 2023 15:28 Go to previous message
I will follow your suggestion.
Thanks for your reply.
Previous Topic:Changing label position when the field is not empty
Next Topic:Corrupted TEXT.nls file for French accented characters + permission not granted error on js build.sh
Current Time: Tue Jul 22 16:41:16 EDT 2025
Powered by FUDForum. Page generated in 0.05656 seconds
