Home » Modeling » Papyrus » ALF code editor alternative(Can't edit or add Alf code to diagram)
ALF code editor alternative [message #1861293] Wed, 04 October 2023 05:58 Go to next message
I'm facing challenges using Papyrus in my research due to issues with different plugin versions. Tutorials often refer to older versions, and when I use newer ones, some functionalities are missing. I got Moka working with an older Eclipse version (eclipse-cpp-2019-09 and Oxygen).
Now, I'm struggling to edit ALF code. Following the steps in this link:
https://wiki.eclipse.org/Papyrus/UserGuide/fUML_ALF_Moka
I can't find the "Alf" editor in the properties tab. "Papyrus Alf" and "Integrated ALF Editor" are unavailable in the marketplace or the update site: https://download.eclipse.org/modeling/mdt/papyrus/updates/releases/oxygen/, even with Eclipse Oxygen.
I also tried to download and instal an older Papyrus release (Papyrus-Update-3.0.0) but the Alf editor in nowhere to be found
Is there a way to edit Alf in the latest versions, or how can I access the older versions of Papyrus?
Your assistance is highly appreciated.
Thanks.
Re: ALF code editor alternative [message #1861436 is a reply to message #1861293] Thu, 12 October 2023 08:59 Go to previous messageGo to next message
It seems that the ALF editor is not available anymore in latest version of Papyrus (remove 7 years ago : https://git.eclipse.org/c/papyrus/org.eclipse.papyrus.git/tag/?h=2.0.0M7).
Sorry for the inconvenient,
Pauline
Re: ALF code editor alternative [message #1861442 is a reply to message #1861436] Thu, 12 October 2023 09:51 Go to previous message
Thank you, Pauline, for your reply, much appreciated.
Is there any other way to edit or insert the ALF code in an existing Papyrus model, for instance in the project root, with an external editor.
Youcef.
Previous Topic:Are there any chinese Papyrus expert in this forum?
Next Topic:Papyrus CommunityDay
Current Time: Mon Jul 21 10:08:27 EDT 2025
Powered by FUDForum. Page generated in 0.04030 seconds
