Large if-then-else results in stack overflow in ANTLR parser [message #1861427] |
Thu, 12 October 2023 06:00  |
I have a grammar containing the following rule:
ConditionalExpression returns Expression:
{ConditionalExpression} 'if' if=Expression 'then' ifthen=Expression (=>'else' elsethen=Expression)?
I have found that a long expression of the form
if True then 42
else if True then 42
// repeat ~50 times
sometimes result in a stack overflow exception in the parser, i.e.,
java.lang.StackOverflowError
at java.base/java.lang.Character.digit(Character.java:9982)
at java.base/java.lang.Character.digit(Character.java:9930)
at java.base/java.lang.Integer.parseInt(Integer.java:650)
at java.base/java.lang.Integer.valueOf(Integer.java:983)
at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.createEIntFromString(EcoreFactoryImpl.java:656)
at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.createFromString(EcoreFactoryImpl.java:142)
at org.eclipse.xtext.conversion.impl.EFactoryValueConverter.toValue(EFactoryValueConverter.java:38)
at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.toValue(AbstractDeclarativeValueConverterService.java:80)
at org.eclipse.xtext.parser.DefaultEcoreElementFactory.getTokenValue(DefaultEcoreElementFactory.java:91)
at org.eclipse.xtext.parser.DefaultEcoreElementFactory.set(DefaultEcoreElementFactory.java:70)
at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.set(AbstractInternalAntlrParser.java:340)
at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.set(AbstractInternalAntlrParser.java:348)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleIntLiteral(InternalRosettaParser.java:18946)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleLiteral(InternalRosettaParser.java:18457)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.rulePrimary(InternalRosettaParser.java:31591)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleListOperation(InternalRosettaParser.java:25807)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleBinary(InternalRosettaParser.java:24585)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleMultiplicative(InternalRosettaParser.java:23938)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleAdditive(InternalRosettaParser.java:23632)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleComparison(InternalRosettaParser.java:22639)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleEquality(InternalRosettaParser.java:21796)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleAnd(InternalRosettaParser.java:21280)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleOr(InternalRosettaParser.java:20816)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleConditionalExpression(InternalRosettaParser.java:32398)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.rulePrimary(InternalRosettaParser.java:31525)
at com.regnosys.rosetta.parser.antlr.internal.InternalRosettaParser.ruleConditionalExpression(InternalRosettaParser.java:32474)
Are there ways to solve this?
A bit more context
Our clients were experiencing crashing language servers when their code contained long if-then-else statements. Upon investigating, I found out that the language server is actually silently swallowing this StackOverflowException, after which it ends up with a Resource with `parseResult` set to `null`. This again results in NullPointerException later whenever a request comes in. I wonder whether the language server should at least log the root cause, rather than silently swallowing it.
A second thing I noticed is that this behaviour is somewhat indeterminate. Running the same repro unit test twice sometimes results in a correct non-null `ParseResult`. I'm not sure why that is.
[Updated on: Thu, 12 October 2023 06:07] by Moderator
Re: Large if-then-else results in stack overflow in ANTLR parser [message #1861454 is a reply to message #1861451] |
Fri, 13 October 2023 08:22  |
I do wonder how other languages such as Haskell handle parsing of large if-then-else expressions. Probably by not using recursive descent in the parser, but rather having a loop? Maybe there is some way of converting the grammer in such as way that the `else` branches are parsed in a loop rather than recursively...
[Updated on: Fri, 13 October 2023 08:23] by Moderator
FUDForum. Page generated in 0.26538 seconds
