Home » Eclipse Projects » Eclipse Scout » Changing label position when the field is not empty(Switching between LABEL_POSITION_ON_FIELD and LABEL_POSITION_TOP)
Changing label position when the field is not empty [message #1861434] Thu, 12 October 2023 08:26 Go to next message
Hi there everyone,
I'm looking for a way to change label position automatically when the field (string, integer, long) is not empty.
In certain forms, I have LABEL_POSITION_ON_FIELD as the configured label position but once the user starts typing in the field, I want the label position to be on top i.e LABEL_POSITION_TOP. And if the value in the field is deleted, I want the label on the field again i.e LABEL_POSITION_ON_FIELD.
It is something I used to do with JavaFX and I would like to reproduce it with Eclipse Scout if possible.
Has anyone done this already?
Thanks a million for your assistance.
JD
[Updated on: Thu, 12 October 2023 08:28] by Moderator
Re: Changing label position when the field is not empty [message #1861450 is a reply to message #1861434] Fri, 13 October 2023 03:40 Go to previous messageGo to next message
Hello JD
I just tried something, it seems that it can work.
In the field class you can add this:
			protected String execValidateValue(String rawValue) {
				if (rawValue==null||"".equals(rawValue)) {
					this.setLabelPosition(LABEL_POSITION_ON_FIELD);
				else {
					this.setLabelPosition(LABEL_POSITION_TOP);
				return super.execValidateValue(rawValue);
When the user exits the field, or clears it, the execValidateValue method is called.
Remark: it doesn't work when the user starts typing, only when he is done. But I am not sure that as a user I would like the field to jump down as soon as I type in it.
Michael
[Updated on: Fri, 13 October 2023 03:45] by Moderator
Re: Changing label position when the field is not empty [message #1861574 is a reply to message #1861450] Thu, 19 October 2023 08:49 Go to previous message
Hi there Michael,
Thanks a lot. It works as expected.
JD
Previous Topic:HelloScout not working with Eclipse 2023-09
Next Topic:Access to Diagnostic servlet
Current Time: Sun Jul 20 21:47:15 EDT 2025
Powered by FUDForum. Page generated in 0.13698 seconds
