Home » Eclipse Projects » Eclipse Scout » Google Chrome High CPU
Google Chrome High CPU [message #1861358] Sun, 08 October 2023 12:43 Go to next message
we are encountering problems using our Scout application. Problem is high CPU usage of Google Chrome.
The same problem is with Microsoft Edge, with Firefox we did nout encounter this.
We tried updating Google Chrome to latest version, but problem persists.
Also, one good point we also reproduced this situation on Eclipse Scout Contacts Demo application.
Steps to reproduce:
Open multiple tabs in Contacts application, and switch beetween TablePage and Form (DisplayHintView). Each time CPU usage is rising and not dropping. Also when doing tab refresh CPU is rising and not dropping.
After few minutes page becomes unresponsive and is not responding.
Using Chrome Developer Tools with Performace Monitor tool there is not any CPU activity while page is very slow and after that not responding.
Problem is found in Windows and also in MacOS using Chrome.
Did any of you find this problem? We are using Eclipse Scout 22.0.41 but I repeat, problem is same on Contacts Demo application.
Re: Google Chrome High CPU [message #1861363 is a reply to message #1861358] Mon, 09 October 2023 02:00 Go to previous messageGo to next message
Hi Mr Robot,
we have also experienced this behavior and have already been able to find out what is causing this behavior.
The chromium issue which we have created is now already solved, please see https://bugs.chromium.org/p/chromium/issues/detail?id=1487583.
The fix is already included in higher versions but there is a chance that one of the following minor upgrades will also correct this bug for 117.
Until then I suggest to use a non chromium browser like Firefox or start the Chrome browser with the following command line argument:
--js-flags="-max-inlined-bytecode-size 0"
Kind regards,
Fritz
Re: Google Chrome High CPU [message #1861370 is a reply to message #1861363] Mon, 09 October 2023 05:07 Go to previous message
Thank you very much for your answer and help.
Previous Topic:Error when building separately the client module: missing artefact helloscout-root:pom
Next Topic:HelloScout not working with Eclipse 2023-09
Current Time: Mon Jul 21 05:05:24 EDT 2025
Powered by FUDForum. Page generated in 1.96222 seconds
