Home » Language IDEs » Java Development Tools (JDT) » Java Exception Handling: Handling Checked Exceptions
Java Exception Handling: Handling Checked Exceptions [message #1861289] Wed, 04 October 2023 02:38 Go to next message
I'm working on a Java application that involves file I/O, and I'm dealing with checked exceptions, specifically FileNotFoundException when attempting to read a file. I want to handle this exception gracefully in my code.
Here's a simplified version of what I'm trying to do:
import java.io.BufferedReader;
import java.io.FileReader;
import java.io.IOException;
public class FileProcessor {
        String fileName = "sample.txt";
        try {
            BufferedReader reader = new BufferedReader(new FileReader(fileName));
            String line;
            while ((line = reader.readLine()) != null) {
                System.out.println(line);
            reader.close();
        } catch (IOException e) {
            System.err.println("An error occurred while reading the file: " + e.getMessage());
In this code, I'm attempting to read the contents of a file named "sample.txt." If the file doesn't exist or there's an I/O error, a FileNotFoundException or an IOException might occur.
I want to improve the exception handling in my code to provide more meaningful error messages and possibly take different actions based on the exception type. Could you provide a concise Java code example demonstrating how to handle these exceptions effectively while keeping the code clean and readable? Thank you for your assistance!
Re: Java Exception Handling: Handling Checked Exceptions [message #1861290 is a reply to message #1861289] Wed, 04 October 2023 03:05 Go to previous message
It's better to ask general Java questions (as opposed to questions about using Eclipse's tools for Java development) on a general forum such https://stackoverflow.com/
Previous Topic:Understanding the KMP Algorithm for Efficient Pattern Searching in Java
Next Topic:Terminal view not displaying commands entered
Current Time: Sun Aug 31 10:23:07 EDT 2025
Powered by FUDForum. Page generated in 0.03581 seconds
