Home » Eclipse Projects » Sirius » Java Service
Java Service [message #1860882] Thu, 07 September 2023 03:03 Go to next message
Hi community !
I'm trying, with no success so far, to get a functional Java Service in my odesign project.
I'm pretty sure that my service is correctly registered, because the autocompletion works and propose the methods that I've written. Also, if I suppress the Java extension declaration, the validation tells me that the services can't be found.
But.
But nothing happens then. For example, I have a simple Task concept with an attribute 'name' and the service below returns nothing:
public String getTaskName(Task task) {
    	return task.getName();
or when I try to calculate a collection, it seems to return nothing:
    public List<Task> getAllTargets(Task task) {
      List<Task> targets = new ArrayList<>();
      targets.add(task);
      return targets;
Have anyone have a clue about what I've missed ?
Thx
Re: Java Service [message #1860884 is a reply to message #1860882] Thu, 07 September 2023 04:21 Go to previous messageGo to next message
The code for the service methods seem fine, so the problem is probably elsewhere.
How do you invoke these in your odesign?
Re: Java Service [message #1860887 is a reply to message #1860884] Thu, 07 September 2023 04:43 Go to previous messageGo to next message
Hi Pierre-Charles,
for example, on a Relation Based Edge whose Source and Target mappings are 'Task node', I'm trying to use the getAllTargets() service in the 'TargetFinder Expression' with
aql:self.getAllTargets()
or in a Label Expression, under the 'Task node', I'm using
aql:self.getTaskName()
[Updated on: Thu, 07 September 2023 04:45] by Moderator
Re: Java Service [message #1861111 is a reply to message #1860887] Thu, 21 September 2023 05:50 Go to previous message
at last, it works... but I had to delete my Eclipse workspace and re-import my projects.
So, I don't know where the problem was.
Previous Topic:Sirius at EclipseCon 2023
Next Topic:Creating multiple views for an element
Current Time: Thu Sep 18 16:00:02 EDT 2025
Powered by FUDForum. Page generated in 0.03690 seconds
