Home » Modeling » TMF (Xtext) » VSCode extension retrieve workspace configuration
VSCode extension retrieve workspace configuration [message #1861028] Thu, 14 September 2023 13:50 Go to next message
I would like to retrieve the client configuration from my xtext language server.
When I call LanguageClient.configuration(...) on server side I get a org.eclipse.lsp4j.jsonrpc.ResponseErrorException: Unhandled method workspace/configuration.
It seems not implemented.
Any idea on how to solve this issue ?
Re: VSCode extension retrieve workspace configuration [message #1861029 is a reply to message #1861028] Thu, 14 September 2023 14:03 Go to previous messageGo to next message
Subclass languageserverimpl. Handle it. Bind subclass in serverModule or mixin for in. Create custom launcher class with new module
Re: VSCode extension retrieve workspace configuration [message #1861037 is a reply to message #1861029] Fri, 15 September 2023 03:15 Go to previous messageGo to next message
Thanks for your answer.
My current design match to what you said. In fact it seems not possible to call the client.configuration(...) during LanguageServer.Initialize(...). I will delay the call later.
In fact my need is to configure a list of project dependencies in VS Code configuration:
"configuration": [
				"type": "object",
				"title": "MyDsl",
				"properties": {
					"mydsl.dependencies": {
						"type": "array",
						"scope": "resource",
						"item": "string",
						"default": [
							"mydsl_common_library"
						"description": "Project dependencies:"
On Xtext side I would like to retrieve this list and store the dependencies in a specialized IProjectConfig and to create a ProjectDescription with a populated list of dependencies. After I will have to create a custom IAllContainerState to link the dependencies with the provided VSCode workspace folders.
Is it a correct approach ?
Re: VSCode extension retrieve workspace configuration [message #1861042 is a reply to message #1861037] Fri, 15 September 2023 04:59 Go to previous messageGo to next message
i am not sure. you need to try out.
native question?
why not store project setup in a special file in workspace?
how do you handle the deps clientside?
can you have a look at the didChangeWorkspaceFolders and didChangeConfiguration impls?
Re: VSCode extension retrieve workspace configuration [message #1861105 is a reply to message #1861042] Thu, 21 September 2023 02:47 Go to previous messageGo to next message
My initial idea was to reuse the VSCode configuration to reuse its editor. But this solution is platform dependent and I prefer now have a custom configuration file for my DSL.
My json configuration file contains the list of project dependencies. When the configuration files is changed I notify the server:
    context.subscriptions.push(
        workspace.createFileSystemWatcher('**/.mydsl/settings.json').onDidChange(() => {
            lc.sendNotification(`workspace/didChangeConfiguration`, undefined)
and on Server side I update the project config and run a new build in case the configuration changes.
I still have some issues with project cross references. When I change a dsl in project A, changes are not reflected in the index of project B(with dep on A).
Re: VSCode extension retrieve workspace configuration [message #1861107 is a reply to message #1861105] Thu, 21 September 2023 03:03 Go to previous message
i assume you need to debug affected calculation / project / workspace manager (e.g. org.eclipse.xtext.build.Indexer)
Previous Topic:How can I prevent my Xtext Maven build from breaking every 3 months?
Next Topic:Grammar Modularity
Current Time: Mon Jul 21 08:28:01 EDT 2025
Powered by FUDForum. Page generated in 0.07678 seconds
