Does 4DIAC support Bluetooth Low Energy connection? [message #1859686] |
Thu, 22 June 2023 08:14  |
I want to use Bluetooth Low Energy connection on Beaglebone. Is there any guideline for this topic? Also, I want to program more features on that Bluetooth connection such as when and what will be transferred and start/stop the communication process, synchronization, multiple devices connection, etc. How can I do that?
Re: Does 4DIAC support Bluetooth Low Energy connection? [message #1860515 is a reply to message #1859950] |
Fri, 11 August 2023 04:15   |
Hi, thanks for your reply. I have another problem. Currently, I want to start a kind of round running independently and within each round I need to perform a chain of actions at a fixed time.
Let's say: Round 1 starts at time 10ms, then action A should be called at 30ms, then action B is called at 40ms, and action C is called at 60ms.
Then Round 2 starts at time 110ms..... will perform those chains of actions again.
Which class should I inherit from to perform those task? I reviewed CEventSourceFB, CExternalEventHandler, CThread, CEventChainExecutionThread, and CThreadBase but not quite clear what's the difference between those and how it works. Can you provide a short description of those and if possible suggest which one I should use?
Again, many thanks for your support.
[Updated on: Fri, 11 August 2023 04:16] by Moderator
FUDForum. Page generated in 0.30673 seconds
