Multiple makefile errors only in Eclipse [message #1860527] |
Sat, 12 August 2023 18:45  |
I have two make files that only differ in the file name.
One workes and one had errors on line 6, 11, and all following lines.
So I copied the working make file to the bad project and ran it with out any modifications, and got the same errors.
I have looked through all the project properties and can not find any differences. Also the run configurations appear to be the same( except for the file name).
If I go to a terminal(cygwin) and "make all" it works just fine. the exe file also works.
The makefile output:
make all
MAKE Version 5.43 Copyright (c) 1987, 2019 Embarcadero Technologies, Inc.
Error makefile 6: Command syntax error
Error makefile 11: Command syntax error
Error makefile 12: Command syntax error
Error makefile 13: Command syntax error
O O O
all lines fail after #11.
I have seen several other request for help all with this same signature
(syntax #6, #11, ...).
I have not included the makefile because it does not seem to matter.
Any hints accepted with favor.
Cliff
[Updated on: Sat, 12 August 2023 18:49] by Moderator
Re: Multiple makefile errors only in Eclipse [message #1860542 is a reply to message #1860535] |
Mon, 14 August 2023 15:19   |
Seam the same to me. Attached eclpise1 is the one that does not work and eclipse2 is the one that does.
Here are the error messages :
14:13:48 **** Incremental Build of configuration Debug for project helloW2 ****
make all
The diff is the diff between the two makefiles.
If do the make in a cygwin window, it works see below.
Cliff@Whitepine /cygdrive/e/Documents and Settings/Cliff/C code/C++/helloW2/src
$ make all
Make1:O: C++ -o hello2.o hello2.cpp
C++ -O2 -g -Wall -fmessage-length=0 -m64 -c -o hello2.o hello2.cpp
Make1:T: C++ -o hello2.o hello2.cpp NEW hello2
C++ -o hello2 hello2.o
ALL Obj:: C++ -o hello2.o hello2.cpp ./hello2
$ ls
hello2.cpp hello2.exe hello2.o Makefile
$ ./hello2.exe
Hello World!!!
I have also tried dos2unix on this makefile. no joy.
Cliff
Attachment: eclipse2.png
(Size: 27.69KB, Downloaded 131 times)
Attachment: eclipse1.png
(Size: 27.91KB, Downloaded 139 times)
Attachment: diff.png
(Size: 50.28KB, Downloaded 154 times)
[Updated on: Tue, 15 August 2023 15:56] by Moderator
Re: Multiple makefile errors only in Eclipse [message #1860593 is a reply to message #1860542] |
Fri, 18 August 2023 19:13  |
OK I found the problem! (I think?)
See eclipse3
There is a Debug(now Default) directory and the makefile in that dir. is the problem.
I deleted the Debug dir. and ran the project. The Debug file reappears and I get the same errors. Under the projects->Environment I changed the CWD & PWD to be helloW2.
They remain as I set them. In the Configuration box (eclipse4) was set to 'Debug' was active. I made a new one 'Default'(eclipse5) and deleted the Debug one.
No Joy!
It still creates the a directory, now called, 'Defaults' with the same results.
How do I change the configuration? The configuration under the run+ does not change it. There is no Edit in the 'manage configurations' screen.
Update.
I accidentally deleted the workspace. Well that was my next move anyway.
Imported it again and it works! Joy, joy, joy.
I still do not know what was in those configurations or where they came from.
Update2: see eclipse6.
The Debug/Defaults directory is the result of having the 'Generate Makefiles automatically' check box in the D/D++ Build page(eclipse6).
Now, why the Eclipse generated make files fail, is another question.
Cliff
Attachment: eclipse3.png
(Size: 7.75KB, Downloaded 138 times)
Attachment: eclipse4.png
(Size: 34.12KB, Downloaded 97 times)
Attachment: eclipse5.png
(Size: 8.31KB, Downloaded 92 times)
Attachment: eclipse6.png
(Size: 33.02KB, Downloaded 95 times)
[Updated on: Mon, 21 August 2023 12:39] by Moderator
FUDForum. Page generated in 0.07785 seconds
