Home » Modeling » EMF » Notification on any eContainer change
Notification on any eContainer change [message #1860388] Wed, 02 August 2023 14:53 Go to next message
I have a model. To avoid programming errors, I want to verify changes in the model where containments are changed.
Is there a way to have an adapter to get a notification on this?
Object is added to a parent, removed from a parent, moved to another parent.
regards
Frank
Re: Notification on any eContainer change [message #1860397 is a reply to message #1860388] Thu, 03 August 2023 01:44 Go to previous messageGo to next message
You could use an org.eclipse.emf.ecore.util.EContentAdapter. Any given object can only listen to changes to its modeled features, so unless there is a modeled container feature, an object will not get notifications about changes to the eContainer, but of course the container will get notifications about changes to it containment features.
Re: Notification on any eContainer change [message #1860447 is a reply to message #1860397] Sun, 06 August 2023 13:09 Go to previous message
The commonest eContainer problem is child stealing. See 3.4 of https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjVlIzWwMiAAxVKTEEAHUrHD9UQFnoECCAQAQ&url=https%3A%2F%2Fwww.eclipse.org%2Fmmt%2Fqvt%2Fdocs%2FICMT2014%2FQVTtraceability.pdf&usg=AOvVaw3RU8rzse9xZmJU7eiRmd6d&opi=89978449
If you ensure that your model has a root 'ElementImpl' class you can just add
	protected void eBasicSetContainer(InternalEObject newContainer, int newContainerFeatureID) {
		if (newContainer != null) {
			EObject oldContainer = eInternalContainer();
			assert (oldContainer == null) || oldContainer.eIsProxy() || (newContainer == oldContainer) || (oldContainer.eResource() == null);
		super.eBasicSetContainer(newContainer, newContainerFeatureID);
to detect abuse and occasionally call
	 * Detach object from its container so that a child-stealing detection is avoided when attaching to a new container.
	public static void resetContainer(@NonNull EObject eObject) {
		EStructuralFeature eContainingFeature = eObject.eContainingFeature();
		if (eContainingFeature != null) {
			EObject eContainer = eObject.eContainer();
			if (eContainer != null) {
				if (!eContainingFeature.isMany()) {
					eContainer.eSet(eContainingFeature, null);
				else {
					Object objects = eContainer.eGet(eContainingFeature);
					if (objects instanceof List<?>) {
						((List<?>)objects).remove(eObject);
in those usually very few places where you really do migrate an EObject.
Previous Topic:[CDO] Managing async view invalidation
Next Topic:How can you change properties of attributes at runtime?
Current Time: Sun Sep 14 06:32:25 EDT 2025
Powered by FUDForum. Page generated in 0.03401 seconds
