Home » Modeling » TMF (Xtext) » Eclipse DSL: Change formatter for projects
Eclipse DSL: Change formatter for projects [message #1860358] Tue, 01 August 2023 02:26 Go to next message
When I click on Project -> Source -> Format, which action is triggered, and how can I modify this action or add a custom formatter for my own DSL files?
Re: Eclipse DSL: Change formatter for projects [message #1860373 is a reply to message #1860358] Tue, 01 August 2023 12:22 Go to previous message
For 1 file Configure the formatter fragment
In the workflow
https://github.com/eclipse/xtext/blob/8385f8b25b6ddde746e8488e6f056c9be13c0be8/org.eclipse.xtext.xtext.ui.examples/projects/fowlerdsl/org.eclipse.xtext.example.fowlerdsl/src/org/eclipse/xtext/example/fowlerdsl/GenerateStatemachine.mwe2#L55
Run the workflow and implement the generated stub class
Should do the trick
For formatting project completely you have to implement something yourself
[Updated on: Tue, 01 August 2023 13:08] by Moderator
Previous Topic:Xtext 2.32.0.M2 is out
Next Topic:LSP Support: Multiple Languages in one Server
Current Time: Sun Aug 31 14:21:25 EDT 2025
Powered by FUDForum. Page generated in 0.06414 seconds
