Home » Eclipse Projects » Eclipse Scout » Tutorial directions give error
Tutorial directions give error [message #1860346] Mon, 31 July 2023 12:02 Go to next message
Hello everyone. I followed the exact directions in the tutorial section.
When I try to Run it gives the following error. Please help.
Done in 1.3s
pnpm install finished successfully!
Running 'pnpm build:dev:watch'
> @contacts/ui@1.0.0-SNAPSHOT build:dev:watch C:\Users\mmkar\eclipse-workspace\contacts\contacts.ui.html
> scout-scripts build:dev:watch
'scout-scripts' is not recognized as an internal or external command,
operable program or batch file.
 ELIFECYCLE  Command failed with exit code 1.
 WARN  Local package.json exists, but node_modules missing, did you mean to install?
Re: Tutorial directions give error [message #1860450 is a reply to message #1860346] Mon, 07 August 2023 01:58 Go to previous message
Run pnpm install first in ui.html project from command line
Previous Topic:A BIG thank you to the Eclipse Scout team
Next Topic:Manual: Extensibility for Scout 23 and later with TypeScript
Current Time: Wed Jul 30 08:32:52 EDT 2025
Powered by FUDForum. Page generated in 0.04050 seconds
