IllegalStateException: Profile <some profile> is not current. Expected timestamp 0 but was 0. [message #1748331] |
Tue, 22 November 2016 05:27  |
Similar to https://bugs.eclipse.org/bugs/show_bug.cgi?id=446138 I get from time to time the following exception during the "Perform Setup Tasks" step. The exact log is
java.lang.IllegalStateException: Profile <some profile name> is not current. Expected timestamp 0 but was 0.
at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.lockProfile(SimpleProfileRegistry.java:854)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:67)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:42)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:543)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:340)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:720)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3121)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3064)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4282)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4276)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4274)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3055)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3030)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2930)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:556)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:682)
I use Oomph v1.5.0.
Any ideas what could be the issue here and how to fix? Should I report a bug at bugzilla?
Usually when I restart Eclipse it works again afterwards.
[Updated on: Tue, 22 November 2016 05:29] by Moderator
FUDForum. Page generated in 0.07244 seconds
