Debugging using Eclipse IDE, source not found [message #1860003] |
Mon, 10 July 2023 04:43  |
Thank you for reading my post.
In the Eclipse IDE, I have a workspace with several interdependent projects:
- four dynamic Web projects,
- one Java project
- and three Web fragments.
After setting breakpoints, when I try to debug my project, instead of allowing me to trace the code step by step after the breakpoint has been reached, I get an empty window with a "Source not found" message and a button labelled "Edit Source Lookup Path".
What is bizarre is that I can trace the code with one of dynamic Web projects but not inside the others.
Can you please help?
Best regards.
FUDForum. Page generated in 0.32071 seconds
