Home » Modeling » GMF (Graphical Modeling Framework) » Hiding property pages of an editor
Hiding property pages of an editor [message #185930] |
Fri, 09 May 2008 05:06  |
I'm using the STP.BPMN modeller in an RCP application. The problem is,
that the "Advanced" tab should be hidden, but how can I do this without
changing anything in the modeller?
Till
Re: Hiding property pages of an editor [message #185969 is a reply to message #185939] |
Fri, 09 May 2008 06:05   |
Hi Antoine,
I'm using the latest modeler from SVN, but without modifications. If I
change something in your modeler I have to publish the changes, right?
This is a problem, I don't have the resources to do so and publishing
the modeller with just one property tab missing would be exaggerated.
Or did you mean with "your own version" that I'm making my own modeler
based on your samples (hide annotation)? Because that is what I have to
do... hide shapes due to permissions of the user.
If there is a way to hide it in my own modeler... how?
Till
Antoine Toulme schrieb:
> Hi Till, you will need to do some coding, and most likely will run into
> limitations of that API.
> If you have your own version of the modeler, you can change the
> contributor id of the modeler, and then redeclare the tabs that interest
> you in the plugin.xml file, with new filters that you will have created
> if that is needed.
> Antoine
> Till Essers wrote:
>> Hi
>> without changing anything in the modeller?
>> Thanks
>> Till
Re: Hiding property pages of an editor [message #186008 is a reply to message #185969] |
Fri, 09 May 2008 07:29   |
Originally posted by: atoulme.intalio.com
Till Essers wrote:
> Hi Antoine,
Not sure I follow what you mean. Do you mean you will have to give the
code back as we are open source ? Since we are not GPL that is not the case.
Well, that's up to you. I would certainly appreciate to have you
contribute to the modeler.
Look at the EclipseCon 2008 tutorial. What I meant here was to subclass
the editor class and have your own editor.
I see three possibilities:
1. You don't code nothing. You open a bug against the BPMN modeler and
ask for us to remove this damn advanced tab, or at least filter it out.
We will eventually take a look at it, but we can't commit for a specific
time.
2. You have coded your own modeler using our tutorial to extend the
modeler, subclassing the BpmnDiagramEditor class. You just need to
override getContributorId() in this class, then use the tabbed
properties extension points to add the tabs you want to your own modeler.
3. The way the properties page is created today is that the
BpmnDiagramEditor class is asked for it through the getAdapter() class.
You override that method and return your own properties page.
Let me know what you think is worthwhile. Please assign the bug to me if
you create one, so I get notified!
Antoine
Re: Hiding property pages of an editor [message #186030 is a reply to message #186008] |
Fri, 09 May 2008 08:19   |
I think I'll take option 2 :)
Seems to be the easiest way.
Till
> Till Essers wrote:
>> Hi Antoine,
> case.
>> to do... hide shapes due to permissions of the user.
> time.
> Antoine
Re: Hiding property pages of an editor [message #186941 is a reply to message #186030] |
Wed, 14 May 2008 08:37   |
I've done option 2 as mentioned before. I've wrote a small tutorial
about how to take control over all tabs. Maybe it will be helpful for
others with the same problem, but where should I send it?
Till
> Thanks
> Till
>> Till Essers wrote:
>>> Hi Antoine,
>>> I change something in your modeler I have to publish the changes, right?
>> case.
>>> modeler based on your samples (hide annotation)? Because that is what
>>> I have to do... hide shapes due to permissions of the user.
>> subclass the editor class and have your own editor.
>> out. We will eventually take a look at it, but we can't commit for a
>> specific time.
>> class. You override that method and return your own properties page.
>> if you create one, so I get notified!
>> Thanks,
>> Antoine
Re: Hiding property pages of an editor [message #186948 is a reply to message #186941] |
Wed, 14 May 2008 08:45  |
Till, the painless way is to create a wiki page.
You can relate it to BPMN by adding those tags:
[[Category:BPMN]]
[[Category:STP]]
You can also open a bug to submit your tutorial as an article for
Eclipse Corner. I will be happy to review it, please add me in CC if you
do that.
Antoine
Till Essers wrote:
> Hi
> Thanks
> Till
>> Thanks
>> Till
>>> Till Essers wrote:
>>>> Hi Antoine,
>>>> right?
>>> the code back as we are open source ? Since we are not GPL that is
>>> not the case.
>>>> publishing the modeller with just one property tab missing would be
>>>> exaggerated.
>>>> what I have to do... hide shapes due to permissions of the user.
>>> and ask for us to remove this damn advanced tab, or at least filter
>>> it out. We will eventually take a look at it, but we can't commit for
>>> a specific time.
>>> modeler.
>>> Thanks,
>>> Antoine
Current Time: Sun Aug 31 22:44:57 EDT 2025
Powered by FUDForum. Page generated in 0.03807 seconds
