Home » Newcomers » Newcomers » Unable to open Eclipse.app(Problem starting Eclipse for macOS M1)
Unable to open Eclipse.app [message #1854676] Fri, 02 September 2022 04:13 Go to next message
Hi all, I am writing to ask you for some solution to a problem with Eclipse version for MacOS Apple Silicon. Every time I restart my Mac it happens that when I open Eclipse the message appears:
"Unable to open Eclipse.app". This is very strange. I solve the problem each time by reinstalling the application but this is really very inconvenient. Do you happen to have any idea how to solve this problem?
Re: Unable to open Eclipse.app [message #1854694 is a reply to message #1854676] Fri, 02 September 2022 09:44 Go to previous messageGo to next message
How and where are you installing it?
Re: Unable to open Eclipse.app [message #1854699 is a reply to message #1854676] Fri, 02 September 2022 11:52 Go to previous messageGo to next message
My guess is that you are trying to run a version of Eclipse for the older Intel chip architecture. The Apple M1 chip does not understand anything of the Intel machine code.
Get the Eclipse installer from <https://www.eclipse.org/downloads/packages/installer>.
Please select the AArch64 option, the x86_64 version does not work.
Use the installer to install Eclipse.
Re: Unable to open Eclipse.app [message #1854703 is a reply to message #1854699] Fri, 02 September 2022 15:30 Go to previous messageGo to next message
Thank you for your response. The version I downloaded is already for the new Apple Silicon processors.
I downloaded the "Eclipse IDE for Java Developers" package from this page: https://www.eclipse.org/downloads/packages/
Re: Unable to open Eclipse.app [message #1854704 is a reply to message #1854694] Fri, 02 September 2022 15:31 Go to previous messageGo to next message
Re: Unable to open Eclipse.app [message #1854711 is a reply to message #1854704] Sat, 03 September 2022 01:17 Go to previous messageGo to next message
And where is it physically located on your machine after you "installed" it?
Re: Unable to open Eclipse.app [message #1854712 is a reply to message #1854711] Sat, 03 September 2022 02:18 Go to previous messageGo to next message
Yes through the installer I moved the app to the Mac's application folder.
Re: Unable to open Eclipse.app [message #1854713 is a reply to message #1854712] Sat, 03 September 2022 02:29 Go to previous messageGo to next message
Well, that's one everyone does who downloads packages. So your saying, you can only run it once the first time?
Have you tried copying it to somewhere in your home folder, i.e., somewhere that's always writable for you personally?
Re: Unable to open Eclipse.app [message #1854715 is a reply to message #1854713] Sat, 03 September 2022 08:39 Go to previous messageGo to next message
Actually this problem happens often but not always. For example, I reinstalled Eclipse yesterday but today when I turned on my Mac it did not give me this problem. It happens sometimes and I don't understand why honestly.
Re: Unable to open Eclipse.app [message #1859746 is a reply to message #1854715] Sat, 24 June 2023 11:40 Go to previous messageGo to next message
I know I'm late to the show, but I think the problem can also be in the operating system. The next time you have similar issues, check general problems for the operating system version you have, due to which the application is not launching.
Sometimes problems with apps not launching on MAC can be solved by resetting NVRAM, PRAM or SMC. But there are many other causes, which have been covered in this article https://setapp.com/how-to/apps-not-launching-on-ventura, which also details possible fixes.
[Updated on: Mon, 26 June 2023 10:33] by Moderator
Re: Unable to open Eclipse.app [message #1860483 is a reply to message #1859746] Wed, 09 August 2023 07:01 Go to previous message
Hey! Facing the same issue can be frustrating. Try this: Go to the Applications folder, find Eclipse, and right-click to choose "Get Info." In the info window, check if there's an option called "Open using Rosetta." If it's there, enable it. This might help Eclipse run better on Apple Silicon. Give it a shot and see if it solves your problem!
Previous Topic:Glassfish JMS
Next Topic:Importing Linked Ressources with Windows Batch script
Current Time: Mon Jul 21 05:53:53 EDT 2025
Powered by FUDForum. Page generated in 0.11559 seconds
