Home » Newcomers » Newcomers » Can't install StatET(Can't install StatET)
Can't install StatET [message #1859631] Tue, 20 June 2023 16:52 Go to next message
I am trying to install StatET.
Chose the base IDE for Java Developers then went to the marketplace but it won't install with these errors:
Cannot complete the install because one or more required items could not be found.
Software being installed: StatET IDE for R (Incubation) 4.3.0.202102180600-r (org.eclipse.statet.r.feature.group 4.3.0.202102180600-r)
Missing requirement: StatET IDE for R (Incubation) 4.3.0.202102180600-r (org.eclipse.statet.r.feature.group 4.3.0.202102180600-r) requires 'org.eclipse.equinox.p2.iu; org.eclipse.jdt.feature.group 3.18.0' but it could not be found
Any idea how to fix this?
Re: Can't install StatET [message #1859642 is a reply to message #1859631] Wed, 21 June 2023 03:15 Go to previous messageGo to next message
Which version is it failing to install into?
Re: Can't install StatET [message #1859651 is a reply to message #1859642] Wed, 21 June 2023 09:08 Go to previous messageGo to next message
That happened with a new install of the latest version.
Re: Can't install StatET [message #1859655 is a reply to message #1859651] Wed, 21 June 2023 09:50 Go to previous messageGo to next message
It looks like those folks included the JDT feature in their feature and that specific version of JDT is only available in Eclipse 4.12 / 2019-06 release. That seems quite old suggesting that StatET is quite old...
Re: Can't install StatET [message #1859656 is a reply to message #1859655] Wed, 21 June 2023 09:55 Go to previous messageGo to next message
It's not old.
https://projects.eclipse.org/projects/science.statet
The latest release was April 6 2023.
Re: Can't install StatET [message #1859657 is a reply to message #1859656] Wed, 21 June 2023 10:22 Go to previous messageGo to next message
The computer is old though.
It is still running Windows 7
Is there a way to install or reinstall JDT?
I just tried it on a newer computer running Linux and it installed fine
Re: Can't install StatET [message #1859662 is a reply to message #1859657] Wed, 21 June 2023 12:28 Go to previous messageGo to next message
You should be able to find the Java Development Tools right in your Install New Software dialog, off of the Help menu. The correct URL for the release
you're running should already be in the list of available update sites.
Re: Can't install StatET [message #1859664 is a reply to message #1859662] Wed, 21 June 2023 13:25 Go to previous messageGo to next message
Somehow I think you are trying to install something old of that project then. Which URL are you using to install their stuff?
Re: Can't install StatET [message #1859665 is a reply to message #1859664] Wed, 21 June 2023 13:41 Go to previous message
Thanks for the help everyone.
I am working from home today and was able to get it up and running in Manjaro.
The work computer is in an acedemic research lab running Windows 7 and can't get an OS upgrade for various reasons.
I will try installing the Java Development Tools when I am back on site tomorrow and then report back here.
Previous Topic:How to debug "event driven " code ?
Next Topic:Initial "Run" response
Current Time: Sun Aug 31 13:56:45 EDT 2025
Powered by FUDForum. Page generated in 0.08494 seconds
