Home » Newcomers » Newcomers » Debugging cloned Python code (How to idetify "local" Python source code ?)
Debugging cloned Python code [message #1859607] Mon, 19 June 2023 20:30 Go to next message
I have successfully cloned Python code from github repository.
I did configure Eclipse PyDev and can run the cloned code , no problem.
I am trying to verify that I can debug the cloned code by changing / duplicating some text in "About.py" module.
I can "save" the changed "About.py" module, run my appliication and I do not see the changes
I have made.
I really do not know what source code I am chnanong, but I am assuming the the application runs from locla repository.
My question i s- how do I verify the actual source the application is running from?
The attached screen shot show the application"project" tree and the "About.py" I am using .
Many thanks for helping me to solve this, appreciate that. .
[Updated on: Tue, 20 June 2023 11:32] by Moderator
Re: Debugging cloned Python code [message #1859608 is a reply to message #1859607] Tue, 20 June 2023 02:19 Go to previous messageGo to next message
You should look here for where best to ask questions about pydev:
https://www.pydev.org/
Re: Debugging cloned Python code [message #1859622 is a reply to message #1859608] Tue, 20 June 2023 11:31 Go to previous message
I am making progress, don't ask how I managed to get debug going....
I would like to share current success and post a screen shot...
How do I do that in "Reply"?
Previous Topic:warning: Debugger speedups using cython not found.
Next Topic:Removing brake points
Current Time: Sun Aug 31 17:54:40 EDT 2025
Powered by FUDForum. Page generated in 0.15548 seconds
