Home » Eclipse Projects » Oomph » oomph configuration in eclipse.ini useful?
oomph configuration in eclipse.ini useful? [message #1859583] Fri, 16 June 2023 16:22 Go to next message
I've recently upgraded my Eclipse to 2023-06. I examined my eclipse.ini which has been used for a few years and versions of Eclipse. I found two lines of oomph configuration:
-Doomph.update.url=http://download.eclipse.org/oomph/updates/milestone/latest
-Doomph.redirection.index.redirection=index:/->http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/
I probably previously copied them from somewhere but I currently have no recollection why I did it.
Questions:
1. What do they do?
2. Are they still necessary or useful for the newest version of Eclipse, i.e. 2023-06?
3. In general how does one learn about the existence and usage of these configuration parameters? In particular, how would one know what the right parameter values should be given?
Re: oomph configuration in eclipse.ini useful? [message #1859598 is a reply to message #1859583] Mon, 19 June 2023 02:06 Go to previous messageGo to next message
The oomph.update.url is a variable used in some of the catalogs to determine the update site from which to install Oomph itself. If not specified, it defaults to https://download.eclipse.org/oomph/updates/latest
Any -Doomph.redirection.* options specifies to URIs separated by -> and will redirect the left-hand URI to the right-hand URI.
There is formation about such things here:
https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Hosting_your_own_index_.2F_catalogs
I need to update that documentation because Oomph as just migrated to GitHub:
https://github.com/eclipse-oomph/oomph/issues/3
So the new value for that will be https://raw.githubusercontent.com/eclipse-oomph/oomph/master/setups/
I don't think either one is strictly needed...
Re: oomph configuration in eclipse.ini useful? [message #1859813 is a reply to message #1859598] Wed, 28 June 2023 11:48 Go to previous message
Thanks!
Previous Topic:Oomph is launching eclipse-inst.exe instead of eclipse.exe
Next Topic:Oomph executable installer
Current Time: Thu Jul 31 01:17:27 EDT 2025
Powered by FUDForum. Page generated in 0.07830 seconds
