Re: Upgrading from IBM Watson IoT Platform Message Gateway to Eclipse Amlen [message #1859919 is a reply to message #1859917] |
Wed, 05 July 2023 08:12   |
Hi Naveen,
Please have a look at this document: https://eclipse.dev/amlen/docs/Troubleshooting/tr00006_.html. Here is what it states:
There are several reasons that the Eclipse Amlen server state changes to maintenance mode:
There is a configuration error. For example:
High Availability might be configured with the wrong IP address for the local replication NIC.
The LDAP Bind DN password might be changed on the LDAP server, and therefore the Eclipse Amlen server cannot connect.
A certificate might be invalid or corrupted.
The system administrator sets the server state to Maintenance by using REST Administration APIs, or by using the Amlen WebUI. For more information changing the server state, see Changing the server state.
The store is corrupted and unrecoverable, or there are insufficient system resources to start the store. When any of these issues occur, the Eclipse Amlen server automatically changes the server state to Maintenance.
A pair of Eclipse Amlen servers in a high availability (HA) pair is incorrectly configured for cluster membership. One server in the HA pair might be configured for cluster membership but the other server in the HA pair might not be configured for cluster membership. For more information about configuring HA on cluster members, see Configuring HA.
To diagnose why the server is in maintenance mode, check the status of the server, and check the log files for possible causes. After you resolve the issue, you can change the server state from Maintenance. For more information about checking the status of the server and changing the server state, see Changing the server state.
If the store is corrupted and unrecoverable, or if there are insufficient system resources to start the store, you might need to clean the store. Cleaning the store deletes all persistent data, including messages, subscriptions, and client states. Do not clean the store unless you want to delete all persistent data on the system. For more information about cleaning the store, see Cleaning the store.
Please let us know if that helps.
FUDForum. Page generated in 0.06199 seconds
