Change Jetty/Maven listening ip/port on Android 6 [message #1859487] |
Sat, 10 June 2023 15:17  |
Hi guys, need help and i hope I'm posting this in the right forum.
I have an android device (router) that uses embedded Jetty v7.5.4.v20111024 (Maven) as the webserver for the router's web interface.
The problem is that it listens to port 8080 on all interfaces - therefore blocking access to external sites - any sites that I try to access is "picked up" by the jetty's router admin control page.
I understood that Jetty comes with a default setting of listening to 0.0.0.0 (all interfaces) on port 8080 - this exactly I need to change, but I have no idea how to do it - which is why I'm posting this here and i'll appreciate any help.
Here's some information from the device itself:
List of files in the directory /data/data/com.android.phone/cache/jetty-0.0.0.0-80-ROOT.war--any-/webinf/WEB-INF/lib (This seems to be the location of the Jetty server runtime classes):
-rw------- radio radio 10474232 2022-09-06 21:06 classes.zip
-rw------- radio radio 77587 2020-04-26 23:31 jetty-client-7.5.4.v20111024.jar
-rw------- radio radio 20195 2020-04-26 23:31 jetty-continuation-7.5.4.v20111024.jar
-rw------- radio radio 115084 2020-04-26 23:31 jetty-http-7.5.4.v20111024.jar
-rw------- radio radio 90950 2020-04-26 23:31 jetty-io-7.5.4.v20111024.jar
-rw------- radio radio 70093 2020-04-26 23:31 jetty-servlets-7.5.4.v20111024.jar
-rw------- radio radio 215624 2020-04-26 23:31 jetty-util-7.5.4.v20111024.jar
Location of the web interface itself (named ROOT.war and is located in /storage/emulated/0/lrserver):
root@cpf906_35_c2k_36g_p:/storage/emulated/0 # ls -l
drwxrwx--x root sdcard_rw 2017-01-01 02:00 0
drwxrwx--x root sdcard_rw 2016-01-01 02:00 apkupdate
drwxrwx--x root sdcard_rw 2016-01-01 02:00 imgss
drwxrwx--x root sdcard_rw 2016-01-01 02:00 lrserver
drwxrwx--x root sdcard_rw 2017-01-01 02:00 obb
root@cpf906_35_c2k_36g_p:/storage/emulated/0 # cd lrserver
root@cpf906_35_c2k_36g_p:/storage/emulated/0/lrserver # ls -l
drwxrwx--x root sdcard_rw 2016-01-01 02:00 contexts
drwxrwx--x root sdcard_rw 2023-06-10 17:51 etc
drwxrwx--x root sdcard_rw 2016-01-01 02:00 tmp
-rw-rw---- root sdcard_rw 10 2016-01-01 02:00 version.code
drwxrwx--x root sdcard_rw 2016-01-01 02:00 webapps
root@cpf906_35_c2k_36g_p:/storage/emulated/0/lrserver # ls -lR
./contexts:
./etc:
-rw-rw---- root sdcard_rw 1420 2016-01-01 02:00 keystore
-rw-rw---- root sdcard_rw 49 2016-01-01 02:00 realm.properties
-rw-rw---- root sdcard_rw 23528 2016-01-01 02:00 webdefault.xml
./tmp:
./webapps:
-rw-rw---- root sdcard_rw 13773890 2016-01-01 02:00 ROOT.war
(The ROOT.war file seems to contain all the .jar files from the previous quote + the html files required to run the web interface from the first picture).
The .jar files of the jetty server each contains a directory named "META-INF/maven/org.eclipse.jetty/<name_of_jar>" that contains a pom.xml and pom.properties files, but I don't know where the setting needs to be changed at, and also I'm worried that if I apply a wrong setting - the web server won't load at all and then i'll basically have no way of connecting to the router.
What change should I do , and where should i do it?
Is it in the jetty-*.jar files' pom.xml files ?
Or in the ROOT.war ?
Or in the webapps' webdefault.xml file ?
Thanks in advance!
Re: Change Jetty/Maven listening ip/port on Android 6 [message #1859566 is a reply to message #1859487] |
Thu, 15 June 2023 11:52  |
Miki Berkovich wrote on Sat, 10 June 2023 15:17The problem is that it listens to port 8080 on all interfaces - therefore blocking access to external sites - any sites that I try to access is "picked up" by the jetty's router admin control page.
I guess I'll be the one to point out that consuming traffic intended for a particular port number, regardless of the intended IP address, is not how routers usually work.
[Updated on: Thu, 15 June 2023 11:52] by Moderator
FUDForum. Page generated in 0.11749 seconds
