Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » BBB doesn't receive multicast address
BBB doesn't receive multicast address [message #1859025] Sun, 07 May 2023 06:33 Go to next message
Good morning at all,
I'm trying to do the step 3 with my BeagleBone Black connected to the pc using the usb ethernet connection. My PC OS Linux Ubuntu) is connected to my modem with a wifi connection and both can ping 8.8.8.8 correctly.
I try to repeat the step 3 of the tutorial but it doesn't work on my BBB. if i do it with my Raspberry PI 3 connected directly to the modem via ethernet it works fine. when i use wireshark i can see that my PC is sending packets to 239.0.0.1 but 239.0.0.1 doesn't send any packet back to me.
Could you please help me to solve the problem?
Nicolò
Re: BBB doesn't receive multicast address [message #1859028 is a reply to message #1859025] Sun, 07 May 2023 15:30 Go to previous messageGo to next message
Hi Nicolò,
on a default BBB multicast communication is not always correctly configured. In our bbb traffic control example there is a section on configuring the network setup : https://www.eclipse.org/4diac/en_help.php?helppage=html/examples/bbbTraficControl.html
Have you tried that?
Alois
Re: BBB doesn't receive multicast address [message #1859029 is a reply to message #1859028] Sun, 07 May 2023 17:10 Go to previous message
Good evening Prof. Zoitl,
Thanks for the answer. I'm using Linux Ubuntu and i'm a new user so i don't know how to do some stuff that could be simple to a more experienced user.
Could you please help me writing me how to solve the problem?
Here below i post the ip route command output from my computer. enxf6ffffffffff is the interface that is connected to the BBB and wlo1 is the wifi connection to my modem.
nick@NicPc:~$ ip route
default via 192.168.1.1 dev wlo1 proto dhcp metric 600
169.254.0.0/16 dev enxf6ffffffffff scope link metric 1000
192.168.1.0/24 dev wlo1 proto kernel scope link src 192.168.1.7 metric 600
192.168.7.0/30 dev enxf6ffffffffff proto kernel scope link src 192.168.7.1
below i leave the result of ifconfig
nick@NicPc:~$ ifconfig
eno1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether c4:65:16:9c:b0:b6 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enxf6ffffffffff: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.7.1 netmask 255.255.255.252 broadcast 192.168.7.3
ether f6:ff:ff:ff:ff:ff txqueuelen 1000 (Ethernet)
RX packets 7710 bytes 8621950 (8.6 MB)
RX errors 2 dropped 0 overruns 0 frame 2
TX packets 5685 bytes 736377 (736.3 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Loopback locale)
RX packets 3653 bytes 438444 (438.4 KB)
TX packets 3653 bytes 438444 (438.4 KB)
wlo1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.7 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::69e8:d334:746f:1f4a prefixlen 64 scopeid 0x20<link>
ether 10:5b:ad:7e:5b:ab txqueuelen 1000 (Ethernet)
RX packets 23259 bytes 18167683 (18.1 MB)
RX errors 0 dropped 4 overruns 0 frame 0
TX packets 14080 bytes 2568561 (2.5 MB)
Nicolò
[Updated on: Sun, 07 May 2023 17:19] by Moderator
Previous Topic:Can't execute the function block i create
Next Topic:OPC UA with freeRTOS LWIP
Current Time: Sun Jul 20 23:29:33 EDT 2025
Powered by FUDForum. Page generated in 0.06961 seconds
